Can you use a metric socket on a sae bolt? socket set questions.
   / Can you use a metric socket on a sae bolt? socket set questions. #41
Nobody has mentioned the HF black impact deep socket sets. $20 per set, SAE or Metric, including a steel box. Cheap and indestructible, at least in my experience. Why pay more?
   / Can you use a metric socket on a sae bolt? socket set questions. #42
Yep, good sockets.
I did break a 22mm one though. Couldn't get a lug nut off the front of a F150.
Tried a regular Craftsman chrome plated. Broke pretty easy with a 2' cheater.
Upped to the HF. 1/3" drive socket, HF adapter up to 3/4" HF breaker bar and 4' pipe + smoke wrench. Broke that socket jumping on the end of pipe.
Ended up letting things cool back down and drilling the stud out. Was doing a brake job so once apart replacing the stud and lug nut was pretty easy.
Might I add that I hate tire shops that just like to hammer things on with an impact rather than use a torque wrench
   / Can you use a metric socket on a sae bolt? socket set questions. #43
... HF adapter up to 3/4" HF breaker bar and 4' pipe + smoke wrench. Broke that socket jumping on the end of pipe.
Well yeah that might do it. :D 200 lbs 4 ft out is 800 ft/lbs, plus count 50% more for jumping on the pipe ...
Way over torqued lug nuts: I took my new Subaru back to the Ford/Subaru dealer for its first 10k mile service. Idiot mechanic torqued the lugnuts so tight it bent the front rotors and now the brakes shuddered. I put up with that for a couple of months then had to replace the front rotors (at a different shop!) on a nearly new car.
That Ford/Subaru dealership went out of business not long after that. Must have been a po'ed mechanic who worked on my car.
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
Portable Bathroom (A55853)
Portable Bathroom...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
Golf Cart (A55787)
Golf Cart (A55787)
