How to cut mule tape?
   / How to cut mule tape? #11
The muletape I’m thinking of is used to pull wire etc through conduit. That would make sense as a lot of jobs spec that it is only used once. The folks on the job end up with a bunch of it. We use a heavy duty scissor type cutter or sharp aviation snips.
   / How to cut mule tape? #12
Sheet metal shears cut the wire, but not the nylon.
What does work?
Get a new set of shears or tighten the bolt on yours after you sharpen them a little.
Sounds like duct tape on steroids:thumbsup:
   / How to cut mule tape? #13
   / How to cut mule tape? #14
Poor guy. Needs a longer shirt or a moo-moo!
   / How to cut mule tape? #15
Regular 1800lb mule tape does not have wire in it and cuts with sharp shears, some of it has a small orange tracer wire woven it, but itç—´ soft and cuts easily too. Can you post a picture of what you have?
This is what telecom guys mean when they says 都hears? Amazon.com : Klein Tools 21-7 Electrician's Scissors, Nickel Plated : Klein Tools : Office Products
Those are exactly what we always used to cut mule tape with. But ours didn't have any steel in it that I remember.
   / How to cut mule tape? #16
Exactly. That is what "mule tape" means to me also. We used it to pull heavy cables thru conduits in the Telecom industry.
   / How to cut mule tape? #17
I used to get it free at work also, and it is awesome. Very easy to untie if you need to tie knots in it.
I have always used a knife to cut it, there is no wire imbedded in any of mine though.
   / How to cut mule tape? #18
I have scrounged mule tape with the wire in it, also. I don't like it with wire and you can pull the wire out in sections so as to have just the flat nylon part. Burn the ends of your tape to stop it from fraying. One neat use for the longer lengths I use is for hunting. I have had deer and hogs go running/rolling down the bluff where I hunt and a couple pulleys attached to trees brings them right back up.
   / How to cut mule tape? #19
I use mule tape all the time for tying light stuff down for transporting. Works great for tying down tarps and such, and I like that you can always get the knot back apart afterwards, even if it's wet. I've only ever just cut it with a sharp knife, but I've not had (or remember seeing) the kind you describe with metal strands in it.
   / How to cut mule tape? #20
poultry shears
Hose Reel (A53424)
Hose Reel (A53424)
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
2003 Hyundai Elantra Sedan (A55853)
2003 Hyundai...
