Splitting the Clutch from the engine
   / Splitting the Clutch from the engine
OK, I am finished with this project. I replaced the clutch rod today, added some hydro fluid and everything is back to normal. Overall this project was 2 8 hour shifts and then 2 3-4 hour shift and everything was back together. I took it for a lil spin around the property and nothing seems to be leaking. Wanted to thanks Chewwy for all the motivational emails and posts on here, he was a great help. If you going to have to split your tractor and you are not in a rush to use it I would say "Go for it". It is not as hard as you think it is going to be. I had one other fantastic neighbor help me a few hours twice and we split this thing and remated the tractor. Everything else I pretty much did on my own. I would change one thing and that would be to label my sandwich bags a little better then I did. I labeled one bag cowling and I was not sure which cowling I was working on when I put things back together. I did end up with what looks like 4 extra bolts. They look like fender hardware. I also noticed I was short a few other bolts, but I think the last owner had removed some bolts from the firewall and never put them back. I ordered everything from Messicks so my tractor has the right hardware now. Thanks again for all the responses and suggestions for splitting the tractor. JOB COMPLETE!!!!!!!!!
   / Splitting the Clutch from the engine #32
I had 2 bolts left over when I split my tractor. I thought that was pretty good.
   / Splitting the Clutch from the engine #33
When's the party?
šŸ˜Ž šŸ˜Ž
I figured 4 extra bolts that are small is better then having 1 larger bolt from the crankcase leftover.
   / Splitting the Clutch from the engine #36
Leftover bolts are only a concern when they have no paint on the heads.
Not sure what that is supposed to mean. When I split my tractor most of the painted bolts were important because. Plenty of non painted are also important.
I am just happy we can joke around about this. If something had went wrong because I had all these extra bolts then I would have been concerned. All good people.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2024 CRATOS ES-800 ELECTRIC DUMPER (A57192)
2024 CRATOS ES-800...
LEEBOY 400T DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T DOUBLE...
UNUSED FUTURE MINI HYD WOOD DRILL (A57193)
UNUSED FUTURE MINI...
