Snow Blade Adding snow plow
/ Adding snow plow #1
dgrudd50
ortonville, mi
L2501
Has anyone out there adapted a snow plow to the front frame of the tractor? Would like to mount (make a mount ) to install on front of tractor instead of using the front end loader.
The idea is that taking off the front end loader I can use hydraulics for the plow.
/ Adding snow plow #2
Ya, there are a good number. There is an OEM option for that on Kubotas. Be careful on the curl circuit. Most curl valves have Regen, which works fine when hooked up properly to to a double acting cylinder. However it won't work right if you hook it up to a pair of single acting cylinders. If you use curl on the joystick (left/right) for angle on the common setup for plows.
/ Adding snow plow
Thanks
