Will front weight bracket B7100 fit the chassis of B6000
   / Will front weight bracket B7100 fit the chassis of B6000 #1
greyman56
Veteran, QLD, Australia
Mahindra 4025 4x4, Kubota B6000 (Zen-Noh), John Deere L100
Hi,
I have a Zen Noh ZB6000 which I'm told is just a B6000. It does not have the bracket on the front of the chassis rails to mount weights onto.
I have been looking for weights and a bracket for the front of this little terror, and was almost going to get the mechanic to fabricate the bracket for me. when a wrecker phoned to say he had the weight mounting bracket from a B7100 but could not remember if it would fit the B6000. Now I could just drive down there to check it out, but the wrecker is about 4 hours drive away, so I'd rather find out if anyone knows the answer to this.
I remember reading somewhere that the little Kubota tractors like B6000, B6100, and I thought it was B7000 as well had the exact same chassis, which would mean that this mounting kit would be suitable for my ZB6000.
Can anyone confirm or dispute this?
Thanks, Graham
   / Will front weight bracket B7100 fit the chassis of B6000 #2
If it is not the correct part, it couldn't take too much to make it work......
   / Will front weight bracket B7100 fit the chassis of B6000 #3
Hi,
Thanks, Graham
Suggest you ask the same question in the GRAY section of the orange forum.
Gray Market & Zennoh - OrangeTractorTalks - Everything Kubota
Since Kubota is all that is discussed on the Orange forum, you have a much better chance someone will know the answer.
My question is why do you think you need front weights? The additional weight just adds to the stress on expensive front axle drive components.
Dave M7040
Thanks for the tip on OrangeTrctorTalks. I have posted over there, but not in that forum. Perhaps that is why I don't have a solution yet.
(grin) Because when I attach a small slasher (supposedly suitable for the tractor) to the 3PL, the tractor does wheel stands. Elsewhere on here they recommended 80-100kg on the front.
   / Will front weight bracket B7100 fit the chassis of B6000 #5
Like your smile.
Does your tractor have a pto which turns, when viewed from the rear, clockwise or counter clockwise?
Dave M7040
Can't remember which direction it goes, but it rotates in the opposite direction to every other tractor on the planet it seems. I had to get blades for the slasher that cut in the opposite direction. But that is working OK as long as I can keep the front wheels on the ground.
   / Will front weight bracket B7100 fit the chassis of B6000 #7
Good you have the pto issue covered.
On my old very heavy 2 WD Nuffield I liked when the snow blower would lift the front wheels off the ground so now I could steer it much more sharply using the left or right rear brakes.
Re weight on front axle: I find people are quick to add tire chains and weight with no idea of the additional stresses these impose + the very expensive repairs to the front axle which follow.
Dave M7040
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2018 Vermeer D23X30 S3 Navigator Directional Drilling Machine (A49461)
2018 Vermeer...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
