Having a blast with our new M62
   / Having a blast with our new M62
Doing some clean up work.
   / Having a blast with our new M62 #72
Mutz, what is the Kubota "boom stopper" on the M62 loader? Is it a mechanical lock or a check valve or something else?
Also, would you mind talking about the process of removing the BH, replacing the 3pt arms and the reverse? Time? PITA? Is the 3pth well designed as a stand alone functioning unit or is it mostly an afterthought?
Thanks. I'm daydreaming. :drink:
-Luke
   / Having a blast with our new M62 #73
I can say removing backhoe could not be easier. I致e removed the m59 before, it痴 the same as my m62 which I haven稚 removed, but it takes less than 10 min. It痴 as simple as removing a quick attach fel.
On edit: what is wrong with this website?? The characters that show up on my text are crazy. Is it something on my end?
   / Having a blast with our new M62 #74
It happens when i cut and paste. You have to edit from within TBN.
   / Having a blast with our new M62 #75
I didn稚 cut and paste.
Didn?t
It?s
Can?t
Those question marks are all appostraphes
Apostrophe seems to set it off
   / Having a blast with our new M62 #76
MutzFarm, I'm interested in what trailer you use to transport your M62. I'm lookin for a good solid heavy duty gooseneck to transport my M7060, but quite honestly I might run out of truck, as I only have an '02 Ram 2500, 5.9 Cummins quad cab long bed. I'd be pushin it.
   / Having a blast with our new M62 #77
What about the "boom stopper" kubota advertises?
   / Having a blast with our new M62 #78
Didn?t
It?s
Can?t
Some smart phones will do it, what model are you using?
And are you on the TBN app?
   / Having a blast with our new M62 #79
It's a mechanical bar lock on the loader boom that prevents the boom cylinder from lowering from the full up position during engine service. It's a safety device found on most construction equipment like TLB's, track and wheel loaders.
I wish all tractors had this safety device built in.
It's on the M59 too.
   / Having a blast with our new M62 #80
I phone 7 and on mobile site.
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
2014 Aerway Aerator (A55973)
2014 Aerway...
(APPROX. 20) 4' X...
405 (A52706)
405 (A52706)
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
