Yanmar fluids
/ Yanmar fluids #1
Lunarius
Germany / Dresden
Yanmar YM2220D
Hello together,
is it possible to use a 5-40W Diesel engine oil instead an 15-40W, since I work in the winter by about 15 ーF with my YM2220D, or should I stay with the recommended 15-40W?
Does it have to be synthetic or partially synthetic oil?
The 90wt oil is recommended for the front axle (4wd). Unfortunately, I do not find this in Germany, only this one, is this the right one?
GL 90
Thx a lot!
Ren
/ Yanmar fluids #2
I run 5W-40 in my 1986 Yanmar, as do many others who live in cold climates. I believe it's actually better for it that 15W-40.
I cannot access the link on the gear oil, but the front ends are likely to tolerate almost any lube. JD has gone from 75W-90 to their low viscosity hydraulic oil as the recommended lube in their front ends. Any current day lube is likely to outperform what was available when that tractor was built.
/ Yanmar fluids #3
Hello together,
GL 90
Thx a lot!
Ren
I see the GL-90 gear oil you linked conforms to specification API GL-3 and is viscosity SAE 90. That was a current spec when these tractors were built but that spec has been superseded by more modern specs for better oil, GL-4 and GL-5. I expect the later oils will be easier to find where you are. All are extremely common for rear-wheel-drive automotive rear axles and similar applications so anything suitable for that, will work for your front axle.
Here's the publication (PDF) from the author of those specs, that describes the improvements:
http://www.api.org/~/media/Files/Ce...lications/1560-Eighth-Edition-April-2013.pdf
/ Yanmar fluids
Thanks, I'll do the oil change then with a 5-40W diesel engines oil :thumbsup:
Does it have to be synthetic or partially synthetic oil for the engine?
I have found a 80W-90 (GL-90, is it the same?) gear oil for the front axle, now the have different variants like GL-3, GL-4 and GL-5 .. which is the right one?
@ California
Thanks for the link, but my english is not good enough to understand everything .. sorry :eek:
/ Yanmar fluids #5
80W-90 is the modern replacement for 90. Both of these numbers represent viscosity. 80W means better in Winter, while modern 80W90 is as good in hot weather as the old specification single-viscosity 90).
But to simplify this: anything sold there that is the common lubricant for the rear axle of a modern rear-wheel-drive automobile, is suitable for your front axle.
/ Yanmar fluids
Thanks California, then I'll get some 80W-90 GL-3 for the front axle, do you know roughly how much I need?
As I saw today, there was just so much oil in the Transmission-/Hydraulicbox that it just covert the first cross on the dipstick.
Unfortunately, I do not know exactly which oil was taken bevor, now I would like to add some new oil, is mixing okay or problematic?
I would not change all the liquids until January when I have time.
Is this one right and how much do I need with FEL?
http://mannol.de/en/?action=accessory_chemical_preview&name=Multi UTTO WB 101
Spec.:
MANNOL Multi UTTO WB 101 API GL-4
Oils for agricultural machinery > Standard engine oils
Corresponds with requirements / specifications / products:
API GL-4
VOLVO WB 101
JOHN DEERE J20C/J20D
FORD M2C134D/M2C86(A&B)/M2C134(A&C)
MASSEY-FERGUSON CMS M1135/M1143/M1145
CNH MAT 3525/3526
J.I.CASE MS-1204/1206/1207/1209
NH 410B/420A
NEW HOLLAND 82948718
KUBOTA UDT Fluid
ALLISON C-4
JCMAS HK P-041
CATERPILLAR TO-2
I.H.C B-5&B-6 Hydran
OLIVER Type 55/Type5J/Q1802
WHITE Q-1705/1722/1766/1766B(UHTF)/1802/1826
DENISON HF-(0-2)
SPERRY VICKERS I-280-S&M2950S
SAUER-SUNDSTRAND&DANFOSS Hydro Static Transfluid
ZF TE-ML 03E
ZF TE-ML 03F
ZF TE-ML 05F
ZF TE-ML 06K
Without you guys, I would be lost ;)
/ Yanmar fluids #7
I can't get to that ravenol link.
UTF, 'Universal Tractor Fluid' is the name here for the fluid used in a large number of tractors. Look for a multi grade UTF. If every brand of tractor is listed on the container, it will serve. And various brands/grades of UTF can be mixed.
/ Yanmar fluids #8
Yes you can mix the gear oils , what's in there with what you bought. As for the GL 3,4,5 it's just new specs. There all backwards compatible. So old stuff can use either spec. But a new application that specs GL5 , you should not use a GL3 oil in. There different additives and such. Your tractor was made in a controlled that did not have those specs and really before the third iteration of that spec was probably out. The spec is put out by API or the American Petroleum Institute. ..which is what I mean a counter that does not use that spec.
As for the oil should for these applications it won't matter full or part syn. But I was thinking that 5w40 was only availible in full syn since the span in oil weights is so large. But I could be wrong I have not looked at that weight oil really. And I don't know what I'd availible over there.
/ Yanmar fluids
Thx guys!
Link should work now.
In Germany it is probably called UTTO = Universal Tractor Transmission Oil.
Can someone tell me how much oil I need for the engine, ft axel and transmission/hydraulic?
PS:
Something else, how can I add my avatar picture here?
/ Yanmar fluids
Thx, I already ordered online yesterday:
20 liter Transmission/Hydraulic oil --> MANNOL Multi UTTO WB 101 GL-4 (J20C & J20D)
8 liter front axel oil --> MANNOL SAE 80W-90 universal gear oil API GL-4
4.5 liter Coolant concentrate --> Glysantin G48
should hopefully be the right fluids now.
/ Yanmar fluids #12
@ California
FOR ALL PEOPLE LOOKING AT OIL QUESTIONS PLEASE NOTE THIS IMPORTANT SET OF FACTS:
OLD SINGLE VALUE OIL CALLOUTS ARE BASED ON HOW THICK THE OIL IS AT 200 DEGREES F , AS IT "IT ACTS LIKE A STANDARD OIL".
WHEN THEY CAME OUT WITH DUAL OIL CALLOUTS AS IN 75W90, THE FIRST NUMBER IS WHAT THE OIL ACTS LIKE WHEN IT IS 32 DEGREES F.
SO WHEN THE MOTOR IS WORKING ALONG, YOU GET THE THICKNESS OF NUMBER 2. WHEN ITS COLD YOU GET THE PROPERITES OF NUMBER 1. SO ITS NO ISSUE USING OIL WITH A LOW NUMBER (SYNTHETIC OIL NATURALLY ACTS THIS WAY). WHERE PEOPLE LOSE THEIR MINDS USUALLY IS WHEN THEY DONT GET THE FACT THAT ITS ALL RELATIVE:
75 W90 = OIL IS AS THICK OR THICKER AT 32 DEGRESS F AS A STRAIGHT 90 WEIGHT IS A 200 DEGREES. IT IS MUCH EASIER ON THE EQUIPMENT AT COLD TEMERATURES BECAUSE IT FLOWS, NO TURNED TO MUD.
SAME WITH 5-40. ITS JUST ALL A BENEFIT TO THE MOTOR IN COLDER WEATHER.
ANOTHER NOTE - GEAR OIL AND ENGINE OIL WERE PURPOSLY MADE TO LOOK LIKE DRAMATICALLY DIFFERENT NUMBERS SO PEOPLE WOUDL NOT MIX THEM UP. GEAR OIL TRULY DOES CONTAIN MORE AND EXTRA STUFF THAN MOTOR OIL. ITS MORE OF A PROBLEM IF YOU PUT GEAR OIL IN AN ENGINE THAN THE OTHER WAY AROUND. SOME APPLICAITONS YOU CAN PUT MOTOR OIL IN A TRANSMISSION. IF YOU LOOK AT THE ACTUAL OIL DATA YOU CAN SEE ALL THESE NUMBERS THESE DAYS AND SEE FOR YOURSELF. 75-90 IS LIKE 5-30 FOR REFERENCE.
/ Yanmar fluids #13
No it doesn't have to be synthetic, or a synthetic blend. Regular ole dino oil will work just fine.
Now, if you are using during the winter, you might want to consider synthetic for better cold engine start ups
/ Yanmar fluids #14
Hello together,
GL 90
Thx a lot!
Ren
Per the Yanmar.jp website, you can run 5W30 and 10W30 in the YM, F and FX series tractors. If temps exceed 85F, 15W40 is preferred.
I had saved off those pages in PDF along with other tractor items per the Yanmar series mentioned.
Why make the tractor work even harder and hard starting in the winter with 15W40 in the crank case ???
Now why did I search this out about the oil in the first place on the Yanmar site? When I had gotten the YM2610 totally restored by Fredrick's, I had asked them what oil was in the crank-case. They replied 10W30. So, that's all I've ever used int the tractor. For one, it's way cheaper than 15W40 anyway.
I just couldn't find anything on the Yanmar USA sites. Not even under the Yanmar Marine. This was all back in 2014.
So, for JCByrd24 5W40 isn't a big deal, but 10W30 would suffice to be the better of the bunch. 5 weight vs. 10 weight at 32F is the difference. Long as you are not working the engine hard. It sure makes for easy starting in the cold. Next week is only 5F as the low. If I need to plow the snow first thing in the morning the Yanni girl will be ready. :)
ALSO, the 10w30 makes turning the engine over really nice. It reduces starter wear and with easy running, less smoke out the exhaust. I had convinced another Yanmar owner of a YM1720 to change from 15W40 to 10W30. It was like night and day with less exhaust smoke out the exhaust pipe. Tim also said the tractor actually felt like it got a few extra Hp out of the deal too. I told him the YM1720 is now back to it's peak Hp once again. The 15W40 is for the AMERICAN IRON tractors for the most part.
I've attached the Yanmar.jp oil grades for Ag tractors page for reference.
/ Yanmar fluids #15
I agree that 10W-30 is probably the preferred oil, that is what my 2012 Yanmar LX manual recommends. Make sure the label on the oil jug says its rated for diesel use, you probably won't find a 10W-30 rated for diesel use at Walmart or Tractor Supply. I purchased mine at NAPA, it was Rotella 10W-30.
That said, I see temps as low as -5 F, and I use my LX for snow removal. After using 10W-30 for the first year I switched to Rotella T6 5W-40 synthetic, it does start easier than 10W-30. Extra cranking isn't required, but there's less smoke, less sputtering, etc at freezing temperatures.
/ Yanmar fluids #16
To each their own on engine oil, it really depends on where you live. 10w30 sounds like a nice all year alternative, but in the winters here we get below zero a lot for days or even weeks at a time, so I elect to put 5w40 in mine and run it all year like that. Its full synthetic, easy to start and has the protection of 40 all year too, and I have not had any problems either. This makes it easy on me because we have 3 diesel cars, 2 diesel trucks and 2 diesel tractors and they all use the same oil.
/ Yanmar fluids #17
I don't think DIESEL rated 10w30 is any cheaper than 15w40. I would thi k it would cost more of anything cause they sell way less of it. Make sure you don't put gasoline rated 10w30 oil in it. It can't suspend the particulates (soot) the same way. Sure it will work but how much are you possibly shortening the life. They make "C" rated oils for a reason and "S" rated oils for a reason . C=compression ignition and S=spark ignition. The second letter of each's code is just the variation they make now. I think we may be on SI now and C? Now?
Most though like me don't want to pay for a syn oil in it, if I did I'd use 5w40. But I use Dino oil and do annual changes, with summer I me temps easily hitting 95 on th regular and often 100f and the fact I actually use my tractor regularly in those temps I am sticking to 15w40 and just let it warm up 10 to 20 mins in the winter before doing any real work.
/ Yanmar fluids #18
For the most part, I run 10W30 because temps here in southern WI get down to 0F.
TSC does sell 10W30 for $14 1-gal jug. Shell Rotella T4, CJ-4. The 15W40 1-gal jug goes for $18. My YM2610 takes 19-quarts plus 1/2 quart for the filter. Thus, 5 jugs is needed. The 10W30 saves me $20 over the cost of 15W40. The 5W40 costs the same as the 15W40.
So, it's a win-win for 10W30 overall on my end. I also have Farm & Fleet out here too. I get a price break on a 5-gallon bucket for the 10W30 too.
/ Yanmar fluids #19
10W30 or 5W40 sound like a good idea for your climate.
Not sure I agree with your calcs however. TSC's 15W40 is presently $20 for a 2.5 gallon (10 quarts) jug. That's $8 per gallon.
/ Yanmar fluids #20
I was only comparing the Shell Rotella 10W30 to the Shell Rotella 15W40 grades. I didn't want to toss in the generic store brands. Someone mentioned the Shell Rotella to begin with, so that was my apples to apples in the cart comparison. LOL
Sure, I could go cheaper elsewhere. I would because TSC is like 45 miles from my place. Farm & Fleet are here in Janesville-WI. Wish there was a Rual King out this way. Even an ASC would be nice. We got a Harbor-Freight out here too. They carry some things for tractors. I was a bit surprised by that even.
24" BUCKET (A64277)
24" BUCKET (A64277)
Valley Pivot Point (A64127)
Valley Pivot Point...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
Linx EQ07018RS 18ft Trailer (A65640)
Linx EQ07018RS...
SCAN TO RECEIVE TEXT UPDATES (A64277)
SCAN TO RECEIVE...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
