3-Point Hitch Major Modification on LS MT125 3pt Hitch
/ Major Modification on LS MT125 3pt Hitch #1
rider7767
Paris, TN
TYM T264 with loader and implements
I hated the fact that I would have to take off a tire to put on and off my 3 pt hitch after removing the backhoe. I machined some parts and made it work like a John Deere 1025R TLB. I hope you enjoy the video. I will till the garden tomorrow with it. :thumbsup:
LS MT125 Major 3pt Hitch Overhaul - YouTube
/ Major Modification on LS MT125 3pt Hitch #2
Thanks for the video, looks a whole lot easier. After you use it, make sure you do a follow up of how it worked / held up to stress. Do you think there is another way to do your mod without having to turn down the pin? I don't have access to a lathe and am very far from any shops. I have a bunch of upcoming projects that I will need to switch back and forth: using the BH, then 3pt attachments, then back....Seems like doing that w/o your mod will be a pita! You mentioned your mod is similar to the green tractor's setup, do they sell a pin that we could use (just bolt it on?) or is there another hole that a second pin could be added the opposite direction for the stabilizer? I have not had the time to be able to look at my tractor this week. Thanks for all the videos that you have been doing. Very informative.
You could always use the pins the way they come. You would not have any sway control, but it would work. I am having a knee surgery tomorrow, but I can fix you some after that.
/ Major Modification on LS MT125 3pt Hitch #6
Very smart! My Mitsubishi tractor used the pins to connect the 3 point arms similar to what you did. I'm not quite sure why LS went with the rod method... stronger?
I am sure it is stronger for the non-backhoe tractors; however, with the backhoe attachment, this rear end is really beefed up. I don't see a need. It is made just as heavy as the JD 1025R.
I sent in an email to LS about the problem and my fix. I got this email back. I sent another email asking about the people who already took delivery? I am waiting on the answer. 1508888089180.jpg
/ Major Modification on LS MT125 3pt Hitch #9
Marketing oversight? That is a strange term for a technical problem.
I thought it was unusual terminology also. I just hope they will send out the fix for free if it is a Marketing Oversight. Oversight means the fault is their's. If they fix this problem, I think the tractor will be just about perfect. I have looked it over from top to bottom and I have had nothing bad to say until I got to the 3 pt hitch.
/ Major Modification on LS MT125 3pt Hitch #11
You could just drill out the sway bar end so the it fits over the threaded end. Use a cotter pin to hold it in place just like rider7767.
It occurred to me this morning that Marketing oversight might mean, they did not think people would be that upset with taking a wheel off to change out the 3 pt hitch.
/ Major Modification on LS MT125 3pt Hitch #13
I agree with that. I have used it as a Swiss Army knife for many tasks and it has been great for everything I need to do. I am working in taming woods and working around the house. Anything much bigger would destroy my lawn or not fit into the spaces I need.
It is a very handy tractor
/ Major Modification on LS MT125 3pt Hitch #15
I'll have to look at the sway bar end to see if it's wide enough to drill out. I may just have to get bigger ends.
I still have not heard back from LS. I hope they send out the fix to all owners at no cost. If not I will cut you some.
/ Major Modification on LS MT125 3pt Hitch #18
I emailed the dealer about the kit. He looked into it and says the lower link kit is available for $240. However, he also said they are working on another kit. Not many details on how that will be different. I will probably wait for now till I know the options. I do want an easier way to do this.
/ Major Modification on LS MT125 3pt Hitch #20
Looks nice.
I went a totally different direction. I will start a new thread for mine.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
