Oil & Fuel 1959 ford 871 select o speed oil type and hydraulic questions
   / 1959 ford 871 select o speed oil type and hydraulic questions #1
skip4x4man
new albany,pa
ford 861,871,kubota 6040,kubota mx4800
what type oil is in the rear end,select o speed transmission housing,hydraulic system.do you fill everything from the same plug under the seat.don't see any other plugs.3 pt hitch arms don't work,but not sure where to check level.any help would be appreciated.thanks in advance
   / 1959 ford 871 select o speed oil type and hydraulic questions #2
You can use the same oil in all three sumps, transmission, hydraulics, and rear axle. Use CNH 134D (Ambra) or equivalent oil.
There are two fill plugs beneath the seat for the hydraulic sump and the rear axle.
The transmission fill/level plug is on the right side and is a common square head pipe plug. Many folks install a street L in the port to facilitate filling and allow another quart or two of oil. The added oil is recommended if one operates the tractor on hillsides.
The hydraulic oil level is checked with the dip stick on the right side behind the footboard. The rear axle oil level is checked at the level plug on the left side of the left axle trumpet at the rear.
FWIW: There is a filter beneath the transmission top cover. Almost certainly it has been decades since it was last changed (if ever). DO NOT attempt to remove the top cover for any reason unless and until you have procured a proper Ford shop manual and read and understood the R & R procedures. Doing so can cause very expensive damage.
Get a proper Ford owners manual.
SDT
thank you for the post,on my 871 there is no dipstick on the right side behind the foot board,there is one on the left side behind the footboard.that is the cover where you seperate the rear from the transmission.
   / 1959 ford 871 select o speed oil type and hydraulic questions #4
skip4x4man per our I&T Ford shop manual FO-31 that covers our 1966 3000 Ford tractor in paragraph 231 it states for the Select-O-Speed the recommended fluid is Ford Spec # M2C41-A transmission and hydraulic oil. I noticed our I&T manual going into detail as how to make band adjustments, etc. Their FO-20 manual should be specific your year and model.
Below is one answer on the type of UTF to use in tractors calling for M2C41-A UTF by a person named Chad.
1976 Ford: Holland..Master..it in the hydraulic reservoir and I
   / 1959 ford 871 select o speed oil type and hydraulic questions #5
Sorry. Yes, left side.
This is the hydraulic sump dipstick.
SDT
SDT
thanks again,do you add oil on the plug under the seat,i still can't get the 3 pt to raise,loosened the plug oh the pump and have oil there but no pressure.
   / 1959 ford 871 select o speed oil type and hydraulic questions #7
There are two fill plugs (not pipe plugs) under the seat on the left side. The one closest to the front is the hydraulic sump fill, the one behind is the rear axle fill.
SDT
found the 2 plugs,the front one on the left has a hose for a remote.will try to put some oil in dip stick hole.thanks again.skip
1240 (A50490)
1240 (A50490)
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
Ford F-450 Utility Truck (A52128)
Ford F-450 Utility...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
