Gen info needed - inherited 284
/ Gen info needed - inherited 284 #1
seasd
London
jinma
I just inherited a Jinma Rhino 284. Think its about a 2000. I cant find any way of disabling the PTO drive - the manual says there should be a lever below the seat on the right but the only levers I have are the Diff, and the Hitch Lift / lower. can't see any others. is the pot on all the time on some of these? Seems a bit weird.
Also I can't get the Hydraulic lift to go down. If I push the lever forward it lifts but if I pull back nothing happens....
Any ideas? Thanks folks
/ Gen info needed - inherited 284 #2
Not a expert on Chinese tractors, but the hydraulic lift is the 3 point hitch? Or does it have a loader?
the three point - sorry
/ Gen info needed - inherited 284 #4
The TPH is only gravity down. You will probably have to stand on it with the control in the down position. Hang an implement on it and it will go down.
Thanks Bob - I don't seem to have any PTO levers at all - I know what every lever does but there isn't a pot one - only the speed setting lever on the rear
/ Gen info needed - inherited 284 #6
How many positions does the speed selector lever have? You may find it has 3 positions, 540 RPM one way, neutral in the middle and 1000 RPM the other way. Mine is like that(05 model) but it also has a main engage/disengage lever located by my right ankle when seated.
/ Gen info needed - inherited 284 #7
My first suggestion is for you to post some pictures of your tractor as then we can make better suggestions to help you and also avoid any confusion.
Pictures should be of the complete tractor from both side and the back. Then closeup pictures of the control levers, dashboard and both sides of the engine.
Do you know the term live pto? Some Chinese tractors come with it, some have it as an option. A live pto will turn even when the tractor is stationary. Older simpler pto's only turn when the engine clutch is release either in neutral or in gear. A third type of pto only turns when the rear wheels are moving. This is not found very often. All have the ability to be disengaged.
The live pto setup will have a clutch for the pto itself and another one for the transmission. Sometimes the same clutch pedal serves both clutches. Push down half way and the transmission is disconnected. Push it all the way down and the pto is disconnected.
We need to figure out if you have live pto or not. Careful observations of the pto shaft while pushing the clutch pedal will tell you a lot. It can happen, more often on newer tractors, that the pto clutch is a separate lever. I doubt this is your case.
Does your tractor have rear hydraulic remotes or a Front End Loader aka FEL? Simple tractors hydraulic systems are built to serve either the 3 pt hitch lifting cylinder or a single acting external cylinder as would be used on a trailer which is dumped by the single acting cylinder. Do you have power steering?
The lift arms will have a feature when in use to regulate the speed which they go down when carrying a heavy weight. Without this feature the implement on the 3 pt hitch would just crash to the ground. Usually there is a hand-wheel adjustment for the operator to use to adjust the decent speed. This feature can also lock the cylinder from gong down.
Look forward to seeing more details and hopefully answers to your questions.
Dave M7040
/ Gen info needed - inherited 284 #9
I have a Rhino flyer that says that tractor has a 2 speed PTO, there may/must be a neutral position as was suggested by Ron Mar. about the only thing that makes sense if there are no other levers.
General Info on Rhino...
Try not to laugh to hard at this Vid, but it does have info about some Rhino tractor features
RhinoFinal.mov - YouTube
2005 International School Bus (A64194)
2005 International...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
