60" 3pt. Core Aerator.
   / 60" 3pt. Core Aerator. #11
They do tend to be seasonal in my area. Spring and Fall. After everyone has used them. Too early for Fall.
   / 60" 3pt. Core Aerator. #12
I just typed in "aerator" using Craigslist and then later SearchTempest.
   / 60" 3pt. Core Aerator. #19
Re: 60" 3pt. Core Aerator.
Core plugs all over the place,? There is a better way. If you own a tiller, find a local welding/machine shop. Have them make straight blades. They make a slice, best form of aeration. I have a Befco tiller, straight blades are an option, look at their greenrite seeder, just a seeder on a tiller body. They have a video I believe. Blade spacing is 3 inch. Too close for me, mount blades on every other hub.Your tiller now performs duel functions.
   / 60" 3pt. Core Aerator. #20
Use the search function and search for AERAVATOR...it is made by first products but they have them for Grasshopper Lawn Mower, Ventracs, and 3 point hitch models. Let me tell you....the aeravator is jut an amazing piece of equipment. It performs wonderfully and does a better job (in my opinion) than a traditntal plug aerator. Go to youtube and type in Aeravator. They are expensive pieces of equipment but you can often find used ones. This is what Scotts and tru green uses in my area. I charge $10 per 1,000 square feet to perform the service. I will only do 2 or 3 yards...but the results are always incredible.
2010 Ford Expedition XLT 4WD SUV (A48082)
2010 Ford...
2005 International 4300 15yd Dump Truck (A48081)
2005 International...
2022 CATERPILLAR 299D3 XE SKID STEER (A50458)
2022 CATERPILLAR...
1993 Harsh Feed Mixer (A50397)
1993 Harsh Feed...
PROCHEM LEGEND CARPET CLEANER (A50460)
PROCHEM LEGEND...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A50397)
Kenco PH9000...
