Fan question
/ Fan question #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
Why do manufacturers add a clutch to the fan on large tractors..The dealer tells me if I will let him lock out the clutch on the fan of my 5093E that my AC will cool better..What purpose is there in having a fan that goes on and off instead of just run all the time?
/ Fan question #2
A fan will rob horse power. Bigger the fan, more HP it takes to run it
/ Fan question #4
I assume that would also decrease fuel efficiency..
Correct, it will decrease fuel efficiency (having fan clutch disabled), but it should less than the load the A/C adds when in use.
/ Fan question #5
The viscous fan is a critical component in the 'system' that keeps your engine at the optimum operating temperature . This is designed by intelligent engineers to maximise performance, power and fuel efficiency... and engine life. It engages/disengages at a pre-determined temp range. Alter that 'system' at your peril.
/ Fan question
I think you helped me figure out the answer to my question. While I absolutely agree with your answer I also now recognize that intelligent engineers have to design a tractor that will not only work in mid August in Texas but also work in North Dakota in Jan..If designing a tractor only to be used in Texas I wonder if they would go to the added expense and complexity of using a viscous fan..I also wonder if they had Texas in mind when they put the AC evaporator and duct work in the roof..
/ Fan question #8
The viscous drive fan has been mechanically locked on my '91 JD 4255 since about '95 or '96. My tractor would get too high operating temp while plowing in Texas heat. My dealer installed the fan lock up kit. I think the fuel saved by a viscous fan would be very minimal. I seriously doubt the fan clutch disengaged while engine was running in the Texas Summer heat. My 4255 uses 3.2 GPH of fuel pulling my JD 467 rd baler making 5.5 ft tall bales at close to maximum hyd pressure on forming belts. Engine has 11,500 hrs on original pistons/loners. For me I'd rather have the AC evaporator in roof than under the seat. I like where my AC vents are located in cab headliner on 4255 better than my Kubota M7040 in dash.
/ Fan question
That is interesting to me..You are the first one I've ever heard say that..You touched on something else I was also thinking about..On a hot day I would think the fan would likely run all the time anyway so I wonder if it would really make any difference..On the other hand I only use my tractor (5093E) in the summertime to cut my pasture with a 10' cutter so perhaps it is cutting on and off..
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
Generator (A64553)
Generator (A64553)
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
