Why I Bought a PowerTrac 425
/ Why I Bought a PowerTrac 425 #1
pajoube
Montana (Near Bozeman)
Former Owner PowerTrac 425 (September 2003)
I was on Ebay looking at used compact utility tractors when I came upon a PowerTrac 418 for sale. I had never seen one before and the design really intrigued me. There was a link to TBN where I found MossRoad and his home page. From then on (early 2001) I began the process to learn more about PowerTrac and their products. I traveled to Louisville for the 2001 Expo as I learned that PowerTrac would be there with all models. Both my wife and I drove different models, digging, moving dirt, testing different attachments and in general getting a feel for the performance. We were hooked from that time on.
I had to wait another two years before I flew to Tazewell to meet the folks at PowerTrac and see their manufacturing operation. Again we tested the 425 and many different attachments and then placed our order.
The 425 with attachments arrived the day after Labor Day, 2003 and I picked up that morning. Drove to a friend’s home to start my very first project, the building of 4 stonewalls in the front of his home. This was a little intimidating as I had only about 20 minutes time on the 425 and now would be doing major work.
The following pictures give you a recap of what I have been doing during my first year of ownership. Each of the attachments has been put through their paces on many projects by time of year. I only had a couple of projects planned when the purchase was made. Little did I know that this little green machine would change my life in the pursuit of projects never dreamed of.
I now have over 265 hours on the 425 (first year) and I can truthfully say this has been the best purchase I have ever made. This is my third tractor over the years.
I do not baby this machine, in fact, it has been totally abused, pushed to its limits, and has done everything I have put it through.
PJ
Forks
After cutting asphalt with special saw, used forks to break free.
PJ
Forks
Lifting the large 4-inch thick slabs for removal to dump.
PJ
Forks
Lifting heavy railroad ties into place for retaining wall at site of new tractor garage.
PJ
Forks
Lifting 480 lb lava rock out of pickup
PJ
Forks
Using straps and slope to pull 1 ½ ton lava rock from trailer. 425 did not hesitate pulling this heavy rock out.
PJ
Forks
Lifting generator out of pickup (very heavy)
PJ
Forks
First project with new tractor. Picked up tractor morning of 9-6-03 and started to move the large rocks and dirt into the building of 4 retraining walls at a friends home. Spent 4 days on this project with the 425 doing very heavy duty. Talk about learning on the job.
PJ
Forks
Bringing rock for placing into trench, which was cut earlier using the mini hoe. Got very good at driving and precision placement within hours of receiving tractor.
PJ
Forks
One of 4 walls we built.
PJ
Forks
Bringing load of bricks (85 lbs each) to wall site at my home.
PJ
Box Blade
Back view of box blade – ¼ inch steel through out.
PJ
Box Blade
Top view with teeth in up position and box blade tilted back.
PJ
Box Blade
Pushing with box blade to fill in trench line.
PJ
Box Blade
Teeth in digging position – very hard packed ground. Made couple of passes in two directions to get soil loosened up and level.
PJ
Box Blade
Pushing into piles – used box blade as much pushing as I did pulling.
PJ
Box Blade
Started to level ground in preparation for cement. Getting into tight areas is no problem for an articulated tractor.
PJ
Mower
Mowing along brick wall – going around objects is very easy with the articulated 425.
PJ
Mower
Ease in cleaning the underside – many use a water hose, others a putty knife, I use both.
PJ
Large Bucket
Back filled dirt on steep slope prior to placing stone boulders for retaining wall at friends home. Very first project for 425 and I.
PJ
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2025 SGB20 20in Hydraulic Grapple Stump Bucket (A64553)
2025 SGB20 20in...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
