electrical issues on older Kubota
/ electrical issues on older Kubota #1
HakonJ
Harstad
Kubota M5950DT
Hi
I have an older Kubota (M5950DT) with some electrical issues. The rear lights on the left side of the tractor don't work at all. If I turn on the indicator to the left, a fuse for the indicator lights blows immediately. Blinking to the right works all fine, as does all the rear lights on the right side. Another fuse blows if I turn on the warning lights. The parking light, which share light "housing" (sorry for my poor vocabulary) with the indicator light, works fine on the front left side.
Is there a short curcuit related to the indicator lights? Could the problem with the fuses blowing be related to the rear lights not working on the left side?
How should I proceed to troubleshoot and fix this problem?
/ electrical issues on older Kubota #2
My guess would be that there is a short to ground (tractor frame) somewhere in the wire going to the left indicator light.
Thank you for your reply. It seems likely that there is a short in the wire you refer to. What I don't understand is why this would cause the brake and driving light not to work at all on the left hand side (unless this is a separate issue). Any clues? Are there any known problem areas when it comes to shorts in these types of wires?
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
Cherry Wood Boards (A65640)
Cherry Wood Boards...
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
KUBOTA KX057-5 EXCAVATOR (A65053)
KUBOTA KX057-5...
Komatsu D61PXi-23 (A64126)
Komatsu D61PXi-23...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
