Radio Install in Kubota RTV1100
   / Radio Install in Kubota RTV1100 #51
I am working on a drop in radio for $89. will be done in 2-3 weeks.
Will it have BT. All I care about is FM and being able to stream from my phone. Also, do you know what size the speakers are for an x1100? Pretty easy to drop the headliner?
Brett
   / Radio Install in Kubota RTV1100 #52
Well as a followup to this , I had success, I ordered that wiring harness that was mentioned earlier in this thread ($19.99 ) US funds , unfortunately the freight to Canada here was $38.00 USD ....and then when I factor the exchange it was almost $80 cdn ....more than I thought was going to happen......but that's okay, it came in yesterday...... I temporarily taped the right colours to the right colours on my Dual radio from a RV I had, and sure enough it worked..........the speakers seem to be in the front part of the headliner (that is where I hear the sound from ) ....so this weekend I will do a proper solder and shrink wrap of each joint and figure a way to hold the radio up there in the slot . My RV (Dual brand) radio did not have a installation frame come with it , so I might have to do some wood trim and other creative means to hold it up there ! So I can confirm that even the Canadian supplied 2016 Kubota RTV X1100 C come prewired with speakers and antennae already in place, you just need a radio and wiring harness from Kubota plug to bare wire.
   / Radio Install in Kubota RTV1100 #53
How much was it going to be to have the dealer do it? Mine charged me $200 I think for a radio with BT capabilities
Brett
   / Radio Install in Kubota RTV1100 #54
Close to $400 CDN .................I had a free radio ,so this way it only cost me $80 CDN
   / Radio Install in Kubota RTV1100 #55
Has anyone removed the headliner? Any suggestions?
   / Radio Install in Kubota RTV1100 #56
Last fall I had a bunch of maintenance done on my RTV1100, including replacement of the speakers (fortunately, the radio was fine). I think the speaker replacement was about $200...I just knew I'd make an expensive mess if I tried ripping into the headliner to get at them for replacement (this belief is from experience; most of my projects turn out that way), so figured it was cheaper to have the dealer do it.
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
Kubota L4701 (A53317)
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
