Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ?
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #1
LuckyPierre
Member
TDY Mass
BX22
I bought a BXpanded brush guard for my BX22, BXP also states it fits BX-1500, 1800, 1830, 2200, X23. I set up correctly but per instructions, well it doesn't even come close to fitting. Pamplet states it "mounts in seconds". I double checked my order/invoice, I have the correct model KBXUA3.
I installed the BXP 2 hanger bolts that the brush guard front arms rest on. When I tried to fit the rear quick attachments tabs that fix to the mower deck quick disconnect I found the two rear holes on the BxPed were 1/1/2 to 2" too long making it impossible to mount without a lot of cutting and fabricating. I'm certain the front bolts are installed correctly.
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #2
Tried to find a photo, but it doesn't show one for a BX22.
BX22
Bruce
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #4
OK. Under Armor, not brush guard.
This is what I was looking for.
I have their Under Armor on my BX2360 and it fits OK.
Can you post some photos of the problem?
Bruce
Your BX2360 calls for a different UA model #. I posted the BX models my UA fit in my first post. Have pictures will post soon.
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #6
It's news to me that they make one for the older models at all. Far as I know, anything older than the 60 series you had to go with Bro-Tek.
BXpanded 'under armor' photo
my first attempt a uploading...you should be able get an idea of the mismatch
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #9
It's been about 5 years since I put mine on, but I think I had to install it with the deck lift arms lowered, then raise it and keep it up. I don't have a mid-mount mower, so it was a one-time installation.
Bruce
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #10
I know you said your invoice shows the correct model, however that doesn't necessarily mean you actually have the correct part.
I would recommend you contact BXpanded & check measurements against what you have as to what the model KBXUA3 should be.
My under armor is for a BX24 & fits perfectly & takes only a few minutes to install or remove.
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
Hydraulic rail grinder (A56438)
Hydraulic rail...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2019 GALYEAN...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
