YM1500D water pump
/ YM1500D water pump #1
reb
Central Arizona
YM1500D
Read a thread started about 7 years ago (http://www.tractorbynet.com/forums/yanmar/181464-yanmar-1500-water-pump-solution.html) and got to thinking.
Hoye now offers a water pump kit for the 1500. It is probably the best way to go. However, my Scotch ancestry and DIY attitude said to try something similar to VT_Hokie's fix. I found a smaller pump than he used for less than $40 on Ebay. Another $40 or so and some miscellaneous copper fittings and steel I had laying around, combined with some time, of which I have more than money, produced a workable solution to the overheating problem.
Got it all together this evening and took the tractor out for about 45 minutes of mowing. The outside temperature was only in the middle 70s, so it wasn't a really strenuous test. I let the coolant temperature get to 160 degrees and turned the pump on. It immediately dropped to about 150 and gradually rose to 165 before I quit. Considering the temperature was getting to 230 (I'm too lazy to change the antifreeze twice a year, so I have used a 50-50 mixture in the radiator) a couple of weeks ago, this seems to do the job. Wish I had done it years ago.
Maybe in a day or so. Still have a couple of things to do to it.
/ YM1500D water pump #4
We need pics, or the folks that would be interested in this fix would need pics of it to try and do something similar. Plus we all like pics.
Picture of the pump. Still have to put some heat shrink on the electrical connections and some nylon lock washers on the pump clamp. water pump.jpg
/ YM1500D water pump #7
Nice looking job, but don't be surprised if it still overheats. If it was hitting 230* on thermosyphon the system apparently has some blockage or loose fan belt or something.
Thanks.
I suspect the high temperatures were at least partially because I left the 50-50 antifreeze in year around. The radiator was replaced a few years ago and I have not noticed any slippage of the belt.
/ YM1500D water pump #9
Light does not come on till 248F according to an old post California posted in another thread , quoting 1danny years ago. So that is still within specs.
/ YM1500D water pump #10
What makes you think the 50-50 mix would make it overheat?, just curious...............Mike
/ YM1500D water pump #12
Thanks Winston, I never would have thought that, must be something to do with the specific gravity of the AF...maybe......Mike
/ YM1500D water pump #13
Cause it does.
Water cools much better than antifreeze, it also does not work in the thermosyphan system the same when there is higher coolant ratio.
/ YM1500D water pump #14
As I have just learned, the thermosyphan system is MUCH more finicky than a water pump. It likes WATER, everything needs to be VERY clean, and numerous small details can make it run hotter. Add a water pump if you have a Yanmar tractor and do not want to worry about it!
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A61574)
2010 Mercury 15HP...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
