Battery Explosion! What Happened?
   / Battery Explosion! What Happened? #11
A friend once had a battery explode in his small aircraft.
He had boosted to start the engine, taxied for take off after doing all his checks etc.
Shortly after take off 'BOOM' ---his battery exploded.
So did his shorts!
He never flew again!
The take was that he probably had a dead cell hence low voltage and the boost got him going.
From there the generator was probably overcharging the 5 good cells and creating hydrogen which ignited---and boom.
Any bodies guess as to what sparked the 'boom'.
   / Battery Explosion! What Happened? #12
I have not been able to figure out what happened to this one in my electric ATV. It stayed on a six-stage charger mostly continuously. At most times on just trickle charge. It was still reading over 12vdc! The vents were clear and open. There was no "boom" that we were aware of, but it's possible that it blew while we were away. It did not freeze. It appears to have been a relatively low-energy event; no explosion. It didn't splatter acid all over the inside of the battery compartment, but sure did a number on my freshly-reconditioned and coated battery trays. I believe it happened days or even weeks before I discovered it.
   / Battery Explosion! What Happened? #13
"hydrogen is quite unique in that it will ignite at almost ANY ratio of hydrogen to oxygen."
Hmm, did not know this. I do know that H2 is very explosive but in a large amount is what I've always believed. I have a hypochlorite generator at work. One of the gasses it releases as it splits the salt molecule...is Hydrogen gas. I will pay more attention to the fan motors that are for moving this out of the building.
   / Battery Explosion! What Happened? #14
"Any thoughts on acid covered clothing? Is rinsing in water, within a short time enough? What happens to sulfuric acid diluted with water when it evaporates? Are you left with the sulfuric acid?"
Be sure to toss them in the washer with your wife's good clothes and tell us how it turned out....if you are still alive afterwards...lol :laughing: Oh, and take pics of her reaction when she finds out. :D
   / Battery Explosion! What Happened? #15
Most often ruin my new and expensive Carhart jacket dragging them around in Nov. Got one running in recondition setting tonight. Checked battery in Kubota and it had a finish charge of 14.7 volts. Seemed high-but the tractor always starts. Tomorrow the Ford diesel with two batteries gets the charger on it while I replace a brake line. With only one eye you become extra careful doing this stuff.
My clothing seem to be OK. I had dropped by to have my friend do a little lathe job and I wasn't in my work clothes.
I don't get it. The battery was mounted around six feet up, with the poly tank of the hydraulic pump just a foot above it. The tank doesn't appear hit at all, but a B&S motor on the floor had the battery terminal assembly puncture the plastic fuel tank. It's like the blast went downward yet the top third of the battery was gone leaving the lower two thirds there.
This makes me quite nervous about charging my 48 Volt Gator. It quite often gets topped up, over lunch or whatever, so you unplug it while still charging and drive it away. Sparky relays and brushes! Surprised it hasn't gone kaboom!
   / Battery Explosion! What Happened? #17
Nope. Hydrogen is odorless. You won't know it's there.
It's theoretically possible you could have smelled a faint whiff of sulfuric acid in the air, as the overcharging boiled it off. Or maybe not.
Actually a normally charging battery will produce hydrogen at the end of its charging cycle. Over charging a battery, or one with shorted cells creates hydrogen sulfide gas that does have a characteristic rotten egg smell. It is also explosive, and toxic.
   / Battery Explosion! What Happened? #18
Many years ago, I worked for Sears Automotive, back in the day when they had an auto catalog(dating myself here) If sears sold it, we installed it. Engines, transmissions, luggage racks.......everything.
We had an electric forklift we used in the shop for whatever we needed, it was always parked, on the charger, at the back wall. One day there was a huge explosion, we all looked over in time to see the forklift about a foot in the air, the whole building shook. Apparently a new guy was cutting up an old exhaust system for the scrap bin, and a shower of errant sparks ended up spraying over the forklift. Management wasn't happy with the repair bill, and the fact they had to have a shelter built outside to store it in from that point.
Couple of years ago my kids took my electric golf cart offroad(they never listen......sigh) one of the batteries broke loose, arc'd and blew, luckily the seat base took the brunt of it. I had to replace the battery, a solenoid and a bunch of wiring, as well as repair the battery tray.
   / Battery Explosion! What Happened? #19
So did his shorts!
Must have been an internal short set that off. There's way too much air blasting around a light plane batter and box to allow hydrogen to build up. Aside from scaring **** out of him it most likely would have done no serious damage aside from tearing apart the box . It sure wouldn't have knocked out the engine and those things run fine even without any battery . It sure would cause some serious pucker factor if it happened in the air.
   / Battery Explosion! What Happened? #20
Starting battery is not the proper design for the application. Should have been a deep cycle or at least a marine battery.
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
2 - TRUCK WHEEL DOLLY (A55745)
2 - TRUCK WHEEL...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
