Drilling a square hole
/ Drilling a square hole #11
Look up "rotary broach" on youtube. SVSeeker has a good video on making one. There are probably others too.
/ Drilling a square hole #12
I'm seeing hex head bolts in a lot of places that would have used a plow bolt in the past. Round hole, use an Allen wrench on one side to hold it.
/ Drilling a square hole #13
Caterpiller sells the bolts for their graders, and seem to be very good quality. Don't remember what I paid for them, but it must not have been too much, cheap as I am, lol!
David from jax
/ Drilling a square hole #14
I am guessing some of you are not familiar with plow bolts:
Similar to a carriage bolt, but it sits down inside a conical hole instead of protruding like a carriage bolt.
Commonly used to mount plow shares onto frames, etc. where a flush surface is desired.
My thoughts on the OP's problems are how much metal would need to come off to simply grind the heads flush to start with?
Since the square section is so short, it may take less time than you think to simply rough out the hole with a coarse square file.
No, just me, but getting up to speed quicker now..................
/ Drilling a square hole #16
This gets my vote, square broaching is to time consuming, I'm slow enough as it is.............
/ Drilling a square hole #18
A push broach would do this; you drill a round hole, then press the broach through it, and it will cut the hole to be square. They aren't super cheap, but if you use it a lot, it would be worth it.
/ Drilling a square hole #19
With the amount of metal removed by the countersink, a small coarse square file might work OK.
/ Drilling a square hole #20
Unless you are doing this every day, you could easily do a bucket an hour with a push broach, which isn't a lot of time.
SDlanch 20'x20' High End Carport (A60463)
SDlanch 20'x20'...
2020 FREIGHTLINER CASCADIA MIDROOF SLEEPER (A60736)
2020 FREIGHTLINER...
Hydraulic Breaker Excavator Attachment (A60352)
Hydraulic Breaker...
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
2015 Kenworth T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 Kenworth T680...
