Hydraulic oil question??? For CT225
/ Hydraulic oil question??? For CT225 #1
BobcatTR
Decatur, IL.
Bobcat CT225
Time to change hydraulic oil and filters, 1st time.
My manual just gives me the viscosity etc of Bobcat oil.
Closest to me is 45 miles.
Is there an eqevelant oil from Napa, where I will get filters?
Thanks in advance!
Terry
/ Hydraulic oil question??? For CT225 #3
I alao use the traveler stuff. I forgot the exact name, maybe premium.
Napa has a very similar fluid, but I can't remember what it's called.
I recommend calling the bobcat dealer and ordering the filters. That's what I do, and they make it easy. They'll ship them to you.
/ Hydraulic oil question??? For CT225 #4
I worried about it at first,but have used Tractor supply universal hydro fluid and it has been fine. The filters are harder to find. I go to dealer. I think I saw them on E-bay. You may be able to cross the number now, but it has been tried unsuccessfully in the past.
Thanks for your help guys! I have a TS, and Napa. Time yo spend some money! Lol
/ Hydraulic oil question??? For CT225 #6
I replaced my hydraulic fluid with the local farm store fluid. Not Tractor Supply, but a good regional chain. Immediately afterwards I got the "sticking pedal" problem. Not positive if the hydraulic fluid was to blame or if it was something I did during the fluid change. It isn't too severe, and goes away if I warm it up, but wish it I could make it go away. Curious if anyone else has had this happen and if they could get rid of it. CT235
I'm still running on original hyd oil and filters.
Gonna change real soon.
I already have the sticky pedal.
Don't believe it was your change that caused it!
I believe from reading elsewhere happens a lot!
A fix would be Great!
I've lubed the linkage etc. Still hasn't helped!
/ Hydraulic oil question??? For CT225 #8
Mine used to stick on occasion. I would hit it with some lube and that would usually help. I cannot imagine that fluid has anything to do with it.
/ Hydraulic oil question??? For CT225 #10
Don't gave my manual handy. What's the number of hours when you need to change hydro oil? Or, amount of time, because I don't gave that many hours on mine.
Thx
1st hydraulic change is 200 hrs, and filters. I just got a manual, I'm at 270.
Gonna get it done next.
/ Hydraulic oil question??? For CT225 #12
HYD oil used in Bobcat tractors IS NOT standard HYD oil. Its transmission/differential fluid. Standard HYD oil will destroy your HST.
Thank you for that clarification!
/ Hydraulic oil question??? For CT225 #15
If I remember correctly it is every 200 hours.
/ Hydraulic oil question??? For CT225 #16
It's only filters every 200h and fluid at 400h. Reference: Kioti CK25/27/30/35 Workshop Manual
/ Hydraulic oil question??? For CT225 #17
Owners with the sticking pedal/slow to return to neutral need to check a few things. With engine OFF dose the pedal return to neutral? If not lube may be the solution. Some tractors were having an issue with the return/dampener cylinder. A replacement upgrade is available. Old style has two bleed screws. Last incorrect hyd oil will cause the issue as well as brake chatter in some cases. :eek:
Me too!
One goes thru the seat plate.
Have to take off seat to unscrew filter.
Glad you said something, MoPops!
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2011 Ford Crown Victoria Sedan (A59231)
2011 Ford Crown...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
