MMM size to HP
/ MMM size to HP #1
JamBoa
Plainview Arkansas
Cub Cadet Yanmar SC2400
About how much HP tractor should I be looking at for a 72" MMM ?
Also cutting pon 6 acres field about how mych time is saved compared toa 60"?
/ MMM size to HP #2
I have a 1620 ford with a 72 MMM.. never had an issue with HP.. I believe that is 25hp..
/ MMM size to HP #4
I pulled a rear mount 72" mower for years with 18 hp (16 pto). I never let the grass get high though. My current primary mower is a 72" diesel zero turn with 31hp, and it is practically unstoppable.
As far as mowing time difference between a 60" and 72" plan on a 20% difference.
/ MMM size to HP
Thanks. I am thinking the 72" ZTR would be faster but will it work better on slopes thana compact tractor
/ MMM size to HP #6
A ZTR will slide, a 4 wheel drive compact tractor will have better traction.
/ MMM size to HP #7
My 4wd b7200 will beat the crap out of my ZTR in steep banks and mud. The ZTR probably mows 50 percent faster in ideal conditions but I'd say that gap would be less if the tractor had equal hp and power steering. The ZTR has a lower center of gravity so in theory it would be a better slope mower but it slides off.
/ MMM size to HP
Some ZTR slide more than others I was just wondering if a 72 inch larger ZTR or would still slide
/ MMM size to HP #9
Can you cut tall grass"3 week summer growth"?
yeah, like this fall before the leaves start dropping I mowed the powerline easement so it will be easier to mulch up the leaves.. if its to long or to thick you may have to go back over it again if some is not cut cleanly if your looking for golf course finish, I'm a knock it down and move on to the next thing on the list guy..
/ MMM size to HP #10
My 72" ztr is only about 200 lbs heavier than my 60" ztr. Conditions vary, but by the time I start sliding I am on a grade that I would never take my tractor on. IMHO the biggest danger of a zero turn is going down a slope forward and having the drive (and brake) wheels slide. The correct way to mow a slope to steep for side to side is to drive up the slope, then back down. Full disclosure, by the time I have to consider driving up a slope and backing down, I use a walk behind mower.
/ MMM size to HP #11
Just Like a pancake across a hot oiled griddle even more when its damp.
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2005 John Deere 7320 (A60462)
2005 John Deere...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
4' FIELD CULTIVATOR (A63291)
4' FIELD...
Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
Kivel 48in Forks...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
