Hello Everyone, first post, and I'm looking for a recommendation for a new tractor. I live on three acres but only mow 1 to 1.5 acres. The rest is high weeds, which I will mow a bath through for the kids. I have a walk out basement at my house and have a slightly moderate sloped hill on one side and a more gradual hill on the other.
For the last 5 year's I've been using a 20 year old MTD Yardman mower that I inherited from my Grandfathers estate. it has a 42inch mower deck with mulching blades. it has worked surprisingly well, however every year i'm replacing parts and i'd like to upgrade to something new that will last 20 years and provide a better cut quality as well as provide other features.
The big thing I was thinking from other features was being able to add a snowblower attachment. I have 75 feet or so of driveway that I would like to snow blow. the drive way is completely level.
I went to two local JD Dealers and both recommended the same unit for my end use, an X380 with a 48" deck and the 44" snowblower with weights and chains. What is everyone's opinion this? Is this the right option? both dealers said that this unit would be best suited for my needs and would have the strongest transmission which should last a long time without having to step to a 500 series. which both thought would be more than what my needs would be.
The only other concern I have right now is storage space for the unit. i'm worried that the overall width of the X380 with 48" deck might be too wide for the area I have for storage in my garage. I have to do some additional measurements and see, how much space I have. it's much tighter in the winter when I'm parking my pick up in the garage. I'm hoping that I'm not going to have to downgrade mowers and continue to use a walk behind snowblower in the winter.
looking forward to everyone's thoughts. Thank you!
Take this from a JDLA115 owner with 204 hours on the hour meter and the same 6 year old 44 inch snowblower snow blower RUUUUUNNNNN!!!!!!!!!!!!!!!!!!!!!!!!
I have the rear weights and chains and the LA115 was worthless against deep snows and I ended up filling the rear tires with windshield washer fluid to add more weight.
One more thing to remember is the rear wheels don't have a lot of power being delivered to them. Mine has only 2.38+- horse power delivered to one wheel.
Their snow blowers are made by RAD in Canada and you need metric tools to change the drive belt and it takes a very long time if you have never done it before (4+ hours)
The large driven belts are $125+ tax and travel, The chute and spout are thin plastic junk and will not survive dealing with ice and snow, I have replaced mine three times already.
I finally found some Gates Series 1 Kevlar V belts(A116 size) from an amazon supplier to replace the expensive JD driven belt and I hope it lasts longer then the jd driven belt. The Series 1 A116 Gates V belts were $44 plus shipping so........... I don't feel bad about buying them.
I also need you to understand that the driven belt is very long and it is also poorly very poorly designed as the V belt is allowed to bounce too much and it affects the total life of the V belt as it is allowed to move too much much too much and the unit needs a second snubber pulley to maintain tension on the driven belt to restrain it the belts would last longer.
The other issues include
All of the the V belt pulleys are not greasable, The auger bearings are not greasable, the support bearing for the impeller is not greasable, the flat snubber pulley and V belt pulley is not greaseable, The twin V elt guide pulleys are not greasable.
The impeller is a three blade plastic impeller(it should have four impeller paddles).
Now to the driven belt change out; you need to remove the cross brace that holds the impeller pulley support bearing and you have to use a heavy hammer to drive it back and then down to remove the belt after you unbolt the 2 V belt guide pulleys that do not have grease fittings.
The other issue is the snow blower sags on the heavy side where the impeller is as the underframe of the snow blower is made from thin steel and is weak.
Owing and operating farm machinery and lawn equipment and snow blowers has taught me a lot and you need ot have two separate machines one for snow and one to mow as lawn tractors are not ment to remove snow.
Which is what Consumer Reports will tell you as well. And I look forward to someone from JD telling me I am wrong, and I don't know what I am talking about and to provide proof.
OH and Stay away from the big box walk behind snow blowers.
Buy a good walk behind snow blower like an Ariens track drive unit or a Yamaha and a new replacement lawn tractor with just the mower.
Its been my experience with John Deere that they love to take your money and then they say "well you get what you pay for". Kubota treated me no differently as a potential customer.
Its fine to read literature and look at a garden tractor in the show room and listen to the spiel but the minute you walk out the door after emptying your wallet you are in a row boat without a pair of oars.
