jmc
Elite Member
- Joined
- Jul 21, 2003
- Messages
- 3,105
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
So, this tractor only has 450 hrs and it always works great. Today I took a break and shut it off and it would not even crank or click when restarting it. Dropped the loader bucket suddenly to jar the tractor and it started right up on the next try. Ran fine until I shut it off again and then it wouldn't crank or click, no matter what. Battery reads 12v and drops to 11v when I hit the starter.
After lunch, tried again, still won't start. Jacked around with the shuttle shifter, seat switch, PTO switch, pulled all the fuses (good), wiring harness connectors- it then started -about 5 times in a row. But now, the transmission won't engage in either direction. No codes showing on the dashboard, neutral light comes on only when in neutral, gear changes show up on the dashboard, but no movement.
This thing can't be dragged to a shop from where it now sits. Any suggestions?
Thanks all.
John
Thanks all.
John
