Whats wrong with my EHSS TC55DA - Jerks into gear with clutch pedal
   / Whats wrong with my EHSS TC55DA - Jerks into gear with clutch pedal #1
shaley
Tidewater VA.
Ford '92 2120
Hoping other owners can help.
My EHSS jerks into gear like you are popping the clutch when using the inching pedal/clutch pedal. If you start from neutral and move the FWD/REV lever into FWD and do not use the clutch the machine makes a smooth take-off. Same for REV.
It may be the pedal position potentiometer of the EHSS module. I measured the pin voltage on the EHSS in order to test the pot and there was no voltage. Is there another way to test the pot itself. Is this just a wire wound pot that I can measure resistance on?
   / Whats wrong with my EHSS TC55DA - Jerks into gear with clutch pedal #2
Glad you posted this!
My son has the same tractor with the same problem.
Waiting on suggestions/answers.
   / Whats wrong with my EHSS TC55DA - Jerks into gear with clutch pedal #3
There are some related threads listed down along the bottom of this page. I remember some of the discussions, and it is usually a frayed or poorly adjusted inching pedal cable, or a bad potentiometer. Also could be moisture and/or corroded connections on the potentiometer.
Turns out the potentiometer is just a 3 wire, pot that can be measured with a Ohm meter.
   / Whats wrong with my EHSS TC55DA - Jerks into gear with clutch pedal #5
Did you get it figured out Shaley? I have this same tractor, I had to replace the cable and potentiometer several Yrs ago but it's been good since (I hope 🙀)
2024 Frontier FL1061S Hydraulic Flail Mower (A55315)
2024 Frontier...
2013 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2013 Bobcat T590...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
