JD 6150R hydraulic hose blows out and return blows out
/ JD 6150R hydraulic hose blows out and return blows out
We finially got mechanic out he replaced the top quick connect too and it works.
/ JD 6150R hydraulic hose blows out and return blows out #12
I just found this thread. Seems that I am in the same situation. I have a 6105R with 3 pairs of eSCV. From the repair manual, it seems that these might be 450 Series.
Looking at the SCVs, I see a cast iron block, then two coupler ports coming off the block. The coupler ports have the drain tubes or hoses. Are you saying that the replacement is of the couplers alone? Don't touch the cast iron block?
/ JD 6150R hydraulic hose blows out and return blows out #13
Yes, replace couplers only. I would go ahead and change all of them. The new replacements are now different and causes problems if at least a pair is changed at once. The new ones are now improved and have eliminated the drain hoses closest to valve block.
/ JD 6150R hydraulic hose blows out and return blows out #14
Thank you for the confirmation.
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
iDrive TDS-2010H...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
