X330 Slow Reverse
/ X330 Slow Reverse #1
edells
Wisconsin
2000 New Holland TC35D, 2017 John Deere X330, 15hp DR Field and Brush Mower
For Mother's Day this year, I got my wife a new 2017 X330. It only has 27 hrs. on it and she said it has become very slow going in reverse. I tried it and it is, in fact, really slow in reverse. I followed the pedal linkage down to where it connects to the shaft and can see that the shaft does move when the fwd and reverse pedals are depressed but it only move a small amount when the reverse pedal is depressed.
I'm not sure if this is an adjustment problem and not sure how it should be adjusted or maybe the problem is internal to the transmission.
Any thoughts/suggestions would be appreciated. I'll probably have to take it in to the dealer - it's just a pain.
Regards,
/ X330 Slow Reverse #2
Dealer is likely to replace the trans under warranty. Just confirm the belt tension spring is correctly fitted and the idler pulleys are rotating freely, so the belt is fully tensioned.
/ X330 Slow Reverse
I checked tensions as you suggested and everything seems to be ok.
I made the following adjustment that I got off of a different forum and it did make some improvement to the reverse speed -
"It doesn't take much to cause this. Follow the pedal under the foot rest. On the pedal arm where the pedal attaches you will see a nut and bolt. Loosen a turn or so and pull up on the pedal while you tighten the nut. Now try it and see what it does."
Thank you for your response. I do appreciate it.
/ X330 Slow Reverse #4
's ok. Understand that by doing that - what you gain in reverse speed you lose in forward speed.
I'd still report your issue to your dealer for future reference in any later warranty claim.
/ X330 Slow Reverse #5
+ what Spanner said.
Richard
/ X330 Slow Reverse #6
:laughing: :laughing:
Sounds a little like my house. Mrs.tiller gifted me a vacuum cleaner years ago so I gifted her a Cox hose reel. I never complain if she vacuums the house.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
SKYJACK SJ86T TELESCOPIC BOOM LIFT (A62129)
SKYJACK SJ86T...
John Deere 6400 Tractor w/ Bush Hog M446 Loader (A64047)
John Deere 6400...
Honda 300 Four Trax (A61166)
Honda 300 Four...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
