Mf gc2300 won't turn off
   / Mf gc2300 won't turn off #1
bmassey
Houston,TX
Massey ferguson gc2300
I am new to the forum and wanted to know if anyone is having the same problem as me and knows a solution. My gc2300 starts and runs fine but will not turn off. I had to kill fuel and it stays running I am guessing off of the crankcase vent. I got it to finally die by taking off the air inlet and choking the motor down. Any help would be appreciated. Thanks
   / Mf gc2300 won't turn off #2
I think this is common among diesal engines and I am pretty sure it has been discussed on this forum before-have you tried doing a search?
I have searched quite a lot but have not had any luck. If you see something please let mr know. Thanks
   / Mf gc2300 won't turn off #4
How long is it running after you cut the fuel & where are you cutting it? I bet it'll run a while on the fuel in the lines.
   / Mf gc2300 won't turn off #5
There is a fuel shut off solenoid on the side of the injector pump. It should get a signal from a relay to turn off for ten seconds when the key is turned off.
The manual also says, you should be able to push on the rubber boot on the end of the solenoid, and turn it off manually.
Thanks for the info after messing with it the last few days I found I am having an ignition switch issue not activating that fuel shut off solenoid. The crazy thing ran for over an hour with the fuel line off going to order a new ignition switch and I think it should be fine.
   / Mf gc2300 won't turn off #7
People have had issues with the ignition switch, that park the tractor where water can get in it.
We have also seen wires break off of it. They can be soldered back on.
   / Mf gc2300 won't turn off #8
Check the 5 amp shut down fuse located in the 3rd slot of the fuse box. These sometimes blow, (open) when there is moisture present from cleaning tractor with garden hose.
   / Mf gc2300 won't turn off #9
Wow . . . that was your very 1st post on TBN??? Obviously you aren't a rookie. Don't be shy on input lol.
AxleHub
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A51039)
2024 Ford F-350...
