Installed Rr work light switch
   / Installed Rr work light switch #1
BubbaJr
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
On my new B2650, I took the front work lights off and replaced them with a pair of LEDs. What an ordeal that was. Then I mounted one of the halogen Kubota lights on the LR corner of the cab where there was an empty plug. Then I found out I needed a new switch for the rear light. So I ordered one from Coleman's, but they had to order it in then ship it. It came today and about 15 minutes later, I was done. The hardest part was waiting a week for the switch to get here.
:D
Does anyone know if there is also a plug for the right rear work light, I couldn't find it.
Joe
Never mind, I found it.
   / Installed Rr work light switch #3
:D
Joe
Do you have a part number for the switch you used for lights?
Was it hard to pull dash off to get to wiring
The part number is TD350-75360 Switch, Work Light.
The installation was surprisingly easy. In the upper part of the dash where the shelf is, there is a phillips head screw that needs to be removed. On the bottom of both sides of the black dash panel are (I believe) 15mm bolts. You can loosen them after you remove the screw and the dash panel can be lifted up and away from the instruments. You don't need to take it off, you just need to be able to reach inside of the dash. After that's out of the way look on top of the wiring harness in the upper part of the dash, for a piece of blue tape. Cut and remove the tape, and that is the plug and wire that goes in the back of the switch. It's easiest to feed the wire through the hole, plug it in to the switch, push the switch into the hole, and then you can reassemble the dash.
If you think about it first, you can just guide the dash panel onto the loose bolts, then tighten them up, replace the screw and you're done. Or you can do what I did, replace the screw in the top, guide the dash to the bolts, realize the dash won't deflect enough to slip over the bolts, then remove the bolts, and reinstall them. :banghead: The whole procedure didn't take as long to do it, as it just took me to describe it.
Good luck,
Joe
PS. The screw and the bolts are not easily visible, you have to look hard to find them, well at least I did.:confused:
BTW, I got the switch from Coleman Equipment, total cost $55.64 incl shipping. They will have to order it, so it will take about a week to show up, but they had the best price and I already had an account with them.
   / Installed Rr work light switch #5
Found harness and got dash cover off
Thank you for part number
You're welcome.
Joe
   / Installed Rr work light switch #7
Got new switch today need to hook up led lights now just need to fab a small bracket and figure out how to adapt to factory 2 pin square connector.
   / Installed Rr work light switch #8
Did you ever find the small connector for your rear work lights?
   / Installed Rr work light switch #10
I found this on amazon the fit good Metra 72-4568 Speaker Harness for Select GM Vehicles they are the same plugs
air compressor (A55758)
air compressor...
2022 Ram 2500 (A55973)
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2023 Kubota KX057-5 Compact Excavator (A55315)
2023 Kubota...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
