A weird one from a while back
/ A weird one from a while back #1
CT230 Fan
Stewartsville, MO
Bobcat CT230
A month or so back, I had been mowing w. my CT230. I decided to was the finish mower off then decided to was the tractor off. After I washed the tractor, I jumped on, started her up and moved the tractor about 50 feet so I could finish cleaning up. At that point I hopped back on the tractor and it would not start. I could hear the solenoid click when I turned the key, but that was it. Spent about an hour looking around, checking connections before I found the problem. A rock had fallen down the hole in the floor for the hydo pedal and somehow lodged itself under the actuator for the safety switch for the hydro pedal. I was seriously close to calling a service tech out. I would have been pretty embarrassed if I had to pay a service tech to find that problem.
Other than that, I still love my CT230, it's done everything I've asked her to do. Great little tractor.
/ A weird one from a while back #2
It is a design problem.It has happened to me several times while running a rotary cutter. It is usually a leaf or a well placed stem. The micro switch and several things under the tractor see more action than they should. A few shields and a guard for the oil filter would be at the top of my list. The radiator seems easier to clog with debris than other tractors I have used.
/ A weird one from a while back #3
Forgot to add, If it won't start after it has been running fine, It is almost for sure a safety switch.
/ A weird one from a while back #4
That switch freezes on mine while blowing snow all the time and I have to get off the tractor, which then quits, and get underneath it to push that switch back down. It gets a little aggravating.
/ A weird one from a while back #5
Why is it quitting? Are you not setting the break?
Try spraying the area first with silicone spray and then keep some of the cold weather Rain -X in a bottle and squirt it once in a while. Snow will not stick to that stuff. Us it on my TV dish too.
TRAILER MOUNTED 1000 GALLON NURSER TANK (A64280)
TRAILER MOUNTED...
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
2009 Blue Bird All American/ All Canadian School Bus (A61573)
2009 Blue Bird All...
Drill Press (A64119)
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
