Really got in a bind (literally)
/ Really got in a bind (literally) #1
gregnohio12
jackson, ohio
9N, Yanmar 2310
OK, so at the risk of sounding stupid, here goes. I have a Yanmar 2310. Great little tractor. Earlier this summer I bought a used KK 60" tiller. Banged up a little, but the price was right. Anyway, the other day I was finishing up turning some ground over for my fall deer plot, when BOOM. This is ground I had been over before. I thought I must have hit a big rock or stump or something of that nature. So I raised tiller, shut everything down and went to see what happened. Truth is, I still don't know. What I DO know is, everything is locked up tight. Tiller, PTO, both tight as can be. After not seeing anything, and not being able to move anything, I thought I would unhook tiller so I could at least have access to tractor. Nice thought, but I could NOT get tiller knuckle off of PTO shaft. It seems really bound up. So, I am stuck. Tractor (and tiller) still in field. Theories? Comments? Ideas? Thanks in advance, I do know from past experiences this is a good group in here. I should mention I have used the tiller several hours over the summer. It DOES have a slow leak but I keep an eye on it.
Greg
:anyone:
/ Really got in a bind (literally) #2
gregnohio12
Try disconnecting top link and lower 3pt hitch arms separate the shaft so all you to do is to is remove the shaft from the pto the see what you got. .............Welcome to TBN.
/ Really got in a bind (literally) #3
I like this. But if its bound up so bad you can't get the PTO shifter to neutral and the locked tiller is therefor locking the rear wheels - maybe after everything is disconnected try driving in reverse to unload the tension in the driveline. Worst case take a vehicle down there and drag the tiller backward until the driveline slides apart.
/ Really got in a bind (literally) #4
I think your chain may snapped in tiller and locked it all up in the tiller gearbox. Like others said get the tiller off by diconneting it and dragging it backward if u have too. Does the tractor dive? Can you get pto in neutral? Once tiller is off you can have a look. Possible there was a catistrauphic failure in your pto gears but that would not be my first guess.
/ Really got in a bind (literally) #5
My first (hopeful) thought is the tiller gearbox has 'let go'. You mentioned an oil leak...
Anyway, Can you release the side-drive on the tiller and rotate anything?
Good plan to remove the tiller from the tractor BUT the very next thing you NEED to do is remove the half PTO shaft from the tractor.
You do not want to start the tractor and accidentally (or unavoidably) engage the PTO with a length of pipe on the rear flailing around like a demented banshee!
/ Really got in a bind (literally) #6
Thinking the same as the others. Maybe take the side cover off the tiller and look in there and see if the chain or gear has bound everything up. Sometimes can use a 2x4 in put it in the tines and rock them a bit to see if you can get a wee bit of movement so you can move release the PTO shaft.
/ Really got in a bind (literally) #8
What connection does your shaft have at the tractor pto? Is it a push button, twist to release, roll pin, or just what? Just wondering why you can't remove it. I know it is stuck but it would be good to figure out how to get it unstuck.
/ Really got in a bind (literally) #9
Manual transmission ? Roll the crankshaft back to unload the PTO. Shouldn't the clutch help you, too ? Need 2 people to get this done.
/ Really got in a bind (literally) #10
Best idea yet!
Part of the problem is: on these the PTO is a direct mechanical connection to the rear tires while the PTO lever is in gear. So as you suggested the tractor has to roll backward a little to unload the PTO tension. Your idea or the 2x4 in the tines, while someone tugs on the PTO shift lever, are likely the most practical next step.
/ Really got in a bind (literally) #11
Try jacking up one rear wheel to release the tension. This works on 4x4s when I've accidentally left difflock in on the road.
I did take off everything but shaft from PTO was locked up tight. I can not get PTO into neutral. I may have to take truck over to try to pull tiller backwards.....
Will give this a shot too
Best idea yet!
And the PTO lever is indeed still in gear.......Sounds like I need to round up an extra set of hands!
I apologize to some that I answered for not "including the quote". Makes it a bit more difficult for folks to sort through!! It will be a few days before I can get my truck over there, but hopefully I can get tiller free from the tractor and go from there. I do appreciate all the good feedback.
/ Really got in a bind (literally) #18
I see you have a 9n as well as this yanmar. Something were always interested in and a tractor that California compares our small yanmars too is the N series. They have the advantage of the weight for pulling ground engaging equipment but give us a comparison of the 2 what you like and where the N shines and where the YM shines.
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
2004 GMC Sierra 2500 (A66408)
2004 GMC Sierra...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
