Rear aux work light power fuse
   / Rear aux work light power fuse #1
powerscol
SW Colorado
CT 235
Does anyone know what circuit or where the fuse is for this power connection is (aux power leads for rear work light). These are the power leads at the rear of the tractor. I was using it to power a sprayer pump and it stoped working. All fuses in the fuse block look good so I am wondering where this fuse is.
Well I sure have egg on my face now :ashamed::ashamed::confused3: Nothing was wrong and the pump worked just as it should. I forgot to switch from the wand to the rear sprayer and the pump just hit the pressure limit and shut off. I did not know the pump even had a pressure limit switch. Its amazing what we learn when we do stupid things:confused3::D
   / Rear aux work light power fuse #3
Your pump is a demand type pump. When setting up a sprayer we always plumb in a regulated return so the pump runs constantly while spraying. This avoids the constant start/stop which builds up heat in the sealed motors and causes them to fail sooner than on a pressure regulated system. Plus you can change the relief pressure if you change spray nozzles that require a different setting for the correct GPA flow..
   / Rear aux work light power fuse #4
We may be kin, I do stupid things on a regular basis.
Deere 35G (A53317)
Deere 35G (A53317)
CATERPILLAR DP25N (A55745)
CATERPILLAR DP25N...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
