My MX4800 Went Tango Uniform. 112 Hours.
   / My MX4800 Went Tango Uniform. 112 Hours. #1
redlevel
Gold Member
100 miles south of Atlanta
Kubota MX 4800
Dealer says a small hose split, allowing all the water/coolant to leak out.
Tractor never steamed or smoked. No "running hot" symptoms whatsoever.
No light or gauge warning. We thought it was fuel starved, suspected water/trash
in the fuel, because that was what the symptoms were like.
Warranty will cover the repairs, but I'm without a tractor for 2-3 weeks.
Very disappointing. The last two brand new tractors I have purchased went down
like this. This one was bought in the Spring.
   / My MX4800 Went Tango Uniform. 112 Hours. #2
It's always the "three dollar" rubber part that dooms the whole she-bang. Unlucky I suppose.
I've got a 57 year old tractor with no rubber parts associated with the engine except the radiator fan.
Split hoses are not on my worry list. Of course some of the other tractors make up for that one. ;-)
   / My MX4800 Went Tango Uniform. 112 Hours. #3
So you are saying the motor is trashed, as in complete rebuild (or new engine).
Running low/without coolant I'd have thought the temp gauge would have been in the red.
   / My MX4800 Went Tango Uniform. 112 Hours. #4
I am surprised that the OP didn't notice coolant on the ground where the tractor was parked. Since all the water leaked out, I guess there wasn't enough left to make steam so the temp. gauge was not exposed to any water to make it work and no water so it didn't boil over.
Maybe they need to install a block surface temp gauge on the OP's tractor.
   / My MX4800 Went Tango Uniform. 112 Hours. #5
I am hesitant to blame anyone for misfortune, but I am really surprised Kubota is warranting a blown motor that tan with no coolant.
Usually if they fault fluid levels or some other routine maintenance item....they deny warranty and point the finger at the owner for neglect.
   / My MX4800 Went Tango Uniform. 112 Hours. #6
If that tractor only had a $10 temperature gage that repair could of been avoided. I don't know why manufactures cheese up on the little things in their products that could prove to be a big savings or convenience. I'm still miffed about my B3030 coming without a 12-volt accessory port. Especially when I just bought a $2,000 riding lawn mower that came with one.
   / My MX4800 Went Tango Uniform. 112 Hours. #7
The mx's do have a temp gauge. (And I bet it got more than $10)
The issue is that air doesn't conduct heat like water. There for a dry system won't show that it's overheating even though it is.
Perhaps a $10 coolant LEVEL sensor. Don't know if the MX has that, as mine has never been low.
But I check my coolant often, and know for sure the gauge works. Cause when it starts flirting with my comfort zone I know its time to clean the radiator and screen. Which happens alot with a bushhog on and a hat tractor.
If the mx4800 the OP has is a gear, and if it's like any of the other gear Kubota I have been around, under normal use you'd think the coolant temp gauge just doesn't work, as they normally don't get hot enough. You really have to run a bushhog or similar pretty hard on a hot day to even see the needle move.
   / My MX4800 Went Tango Uniform. 112 Hours. #8
I was thinking in terms of a gage that reflects the actual temperature of the engine, not an idiot light.
   / My MX4800 Went Tango Uniform. 112 Hours. #9
In the late 1980's I restored a Dodge Challenger and did a lot of work to the engine. Short version, I didn't add coolant. I actually caught the problem because the temp gauge wasn't moving at all. I caught it pretty quick with no damage. The OP maybe parks it outside, coolant leaks out in the dirt or grass, temp gauge doesn't move................
   / My MX4800 Went Tango Uniform. 112 Hours. #10
Yea, that's what I am saying. It has one.
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
6 Trench attachment (A50322)
6 Trench...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
TMA (A49461)
TMA (A49461)
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
