What on God's green earth is wrong with my mower???
   / What on God's green earth is wrong with my mower??? #1
Phillip w
whiting ks
allis Chalmers 185 and massey ferguson 1531
I have a cub cadet zerI turn mower with a brigigs and Stratton engine. I am not bashing nothing, but the fuel delivery system is definitely not the way I would have done it. If you old school, think of the days when every thing was gravity flow and if you had trouble you just tweaked the needle valve cause that is how it is acting. It misses, lopes, sometimes run with choke on sometimes runs with off and sometimes runs real good for a couple of passes. I replaced all the gas lines, fuel filter, fuel pump, no fix. I thought maybe I got bad gas. Siphoned the tank, put fresh gas in it, no fix. The is some kind of electrical something on the bottom of the carburetor, anybody know what it does? I'm at a loss with tis thing.
   / What on God's green earth is wrong with my mower??? #2
Sounds like you have some junk floating around in the carb, Need to remove it and do a good cleaning. and that thing on the bottom of the carb is the anti bang solenoid.
Hey randy, thanks. I may not want to fiddel with the carburetor. Carburators have never been my strong suit even back in the 70's be fuel injection. We have a small engine man at our local farm and home that is pretty good. Looks like I'm loading it up and taking it to town.
   / What on God's green earth is wrong with my mower??? #4
I agree that you have carb issues. Take it apart, clean it real good, and try again.
The thing with the wires is a fuel stop. It shuts fuel off to the intake immediately when the key is turned off. Prevents a loud backfire like so many small engines are notorious for.
   / What on God's green earth is wrong with my mower??? #5
Put some Seafoam in gas tank (with the gas), run it for 5-10 minutes, shutoff and let sit for 20 minutes, then run it again. It will often clean out the issue.
   / What on God's green earth is wrong with my mower??? #6
You can often e-bay buy a complete replacement carb for only a little more than a rebuild kit. You'll need your EXACT engine model/serial/build numbers.
   / What on God's green earth is wrong with my mower??? #7
I was never a fan of mechanic in a bottle but slowly coming around thanks to E fuel,EPA compliant fuel delivery systems and recent experience with Seafoam. Wood chipper barely ran and bogged down when fed small branches,seafoam helped A BUNCH so I'll use chipper until it won't do the job before trying to get it back 100%. 20 hp briggs lawn tractor has required a liitle choke to prevent surging for 3 years then out of the blue,hardly ran at full chock. Drained tank, added 1 quart gas + 2 oz seafoam,started up to run 5 minutes,killed it,went back next day and it ran much better. Added 2 gallons gas and it's ran every since WITHOUT ANY AMOUNT OF CHOKE. Haven't tried it in oil yet.
   / What on God's green earth is wrong with my mower??? #8
I have a late model Toro push mower that has absolutely no carb adjustments and doesn't even have a choke. It has electric start and ran fine when new. After a few seasons of Ethanol gas it would start and immediately die 5 or 6 times and then surge awhile before I could use it. I poured sum Gumout carb cleaner formulated for ethanol problems in the tank. The next week it started right up and ran fine. I now pour a little into the tank every month.
Bob B.
Hey guys, just an update. I took my mower to the "fix it guy". Yep carburetor was a mess. The cleaned it all up and it works good now. Thanks again guys.
   / What on God's green earth is wrong with my mower??? #10
As a Seafoam believer, put some in the tank on a regular basis and add more before you store for the winter. Then run it out of fuel before storing and start with fresh gas in the spring. Even better is to just use non-ethanol gas if you can get it. Seafoam works and ethanol doesn't and if you don't pay attention will likely have this problem again.
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
(INOP) 1992 FORD F-150 TRUCK (A52708)
(INOP) 1992 FORD...
206320 (A57192)
206320 (A57192)
