Comparison Help me compare these 4 tractors!
/ Help me compare these 4 tractors! #1
Olympus
Cape Girardeau, MO
LS R3039
My wife says I'm about to worry her to death with all my obsessing over which tractor to buy. She's really put a lot of pressure on me with the "this is the last tractor we're going to buy and I MEAN IT" speech. So here are what I'm looking at with what I perceive as the pros/cons of each. Please help me with what you would choose. I live on 6 acres and I mow 3 of it with a ZTR mower and the other 3 acres I brush hog about 4 to 5 times a year. I have a 350ft gravel driveway that I maintain. I also have a 100 acre hunting property that I trailer my tractor to. The 100 acres is all timber except for a 2 acre old pasture that I let grow up and brush hog once in the winter and 2 acres of food plots that I put in. I also brush hog the ATV trails and would like to make some new ATV trails with a brush hog. Most of my loader work has been done already by my previous tractor, but there will be occasion to need to use loader work again I'm sure not to mention the general pushing around of things an back-dragging. So there is my situation in a nutshell and what I would be using the tractor for. I already own a 5ft brush hog, a 6ft finish mower, and a 6ft landscape rake. My father in law has a 5ft rototiller that I can borrow for tilling up the garden twice a year.
John Deere 3032E with only 90 hours and 2014 year model. Loader has never even been used and the machine literally looks like it's brand new. No scratches, dents, or dings anywhere. Still has warranty left. Hydro tranny is nice and the two ranges don't really bother me much. My last tractor only had two ranges. Good dealer network close by for parts and service. Negatives include a non-foldable ROPS (worried about limbs and branches when working at my hunting land), vertical exhaust (again worried about branches and limbs), concerned it may not be as heavy and/or wide as I like for stability and traction. But the non-foldable ROPS and vertical exhaust are my biggest worries because I know they will become a headache at some point. I'm not sure about the weight and width of the machine. I may find myself wanting more traction or stability or it may work out just fine. I probably wouldn't worry about removing the loader frame, so that's really a non-issue. And I don't use anything on a mid-PTO so not having that is also a non-issue for me.
Kubota L3200 HST with only 165 hours and a 2013 year model. Here is a link to the actual machine: 213 Kubota L32 HST 4WD for sale in Columbia, MO | Farm Power Lawn & Leisure (573) 442-1139 I like the Kubota brand, like that it's a hydro tranny, and looks to be very clean. Rear tires are filled with Rim Guard. Negatives are the bucket is pinned on and dealer says probably $500 to convert to SSQA. Also potential negative is the treadle pedal design. My last tractor had the two pedal system and I much prefer that, but some say it's a matter of just getting used to something different. Also read that the 3pt arms can be jerky, but I haven't asked if that's the case on this machine. It's about 600lbs or so heavier than the Deere, so that gives me a little more piece of mind.
LS R3039 shuttle shift with only 187 hours and a 2013 year model. Has factory warranty until December 2018. Looks to be a very clean machine also. Original owner was a mechanic and took excellent care of the tractor. Biggest like is 39HP engine and 30HP at the PTO! Also has two sets of rear remotes! Has a suspension seat and tilt steering column. No emission junk to worry about either, just a regular 4-cylinder Mitsubishi diesel engine. Has detachable loader frame and SSQA bucket. Has telescoping stabilizers instead of turnbuckles and telescoping 3pt arms also! Tractor with loader weighs almost 4000lbs without fluid in the rear tires and is wide so I feel very confident that I would not be wanting for power, traction, or stability with this particular tractor. I have a strong LS dealer network in my area and my last tractor was an LS. I've been happy with the brand and with the dealers.
Branson 3520R shuttle shift with 304 hours and a 2013 model. Has factor warranty left until some time in 2018 also. Exceptionally clean machine with one owner. Owner also provided additional air and oil filters to the dealer when it was traded in. This tractor is the biggest frame size of all 4 options. It's taller, wider, and much heavier. It's closer to 5000lbs with the loader. Lift capacity is the highest of the 4 also at over 2000lbs. Has fender mounted loader joystick, has telescoping 3pt arms, has independent live PTO. And I'm not sure if this is good or bad, but the dealer said that these tractors have mechanical injection pumps instead of electronic injection. So I'm not sure if that's a good thing or a bad thing. Has a detachable loader frame and SSQA bucket as well. Possible negatives are that there's only 1 dealer reasonably close (40 miles) and it's a very small shop. Guy assures me that Branson factory is very responsive to their calls and he can get parts in about 3 to 5 days. Branson isn't a large or as well known of a brand, so I would hate to buy a machine and then be hours away from the next dealership if this guy closed the doors. Or even in Branson stopped making tractors altogether.
/ Help me compare these 4 tractors! #2
Buy the heaviest bare weight tractor.
From TractorData.com:
John Deere 3032e 2,175 pounds
Kubota L3200 HST 2,500 pounds
LS R3039 ........... 2,780 pounds
Branson 3520R 4,053 pounds
I believe Branson will be around. Branson is the price leader.
Long term viability of any individual dealer, regardless of brand, is unknowable. Especially true if "the next generation" will take over.
You did not buy ENOUGH TRACTOR the first time. Buy enough this time.
( I did not buy enough tractor until my third purchase.)
Maybe I'm wrong, but there seems like a lot more factors to consider when buying other than which is the heaviest bare weight tractor.
/ Help me compare these 4 tractors! #4
Jeff is misinformed about the LS R3039. The bare LS tractor does weigh 2780 plus 1058 for the loader and about 200 or so for the bucket totaling 4038 lbs. I didn't look up the JD or Bota but suspect listed weight is for the bare tractor and they weigh in the same ballpark with loader and bucket. The Branson weight probably includes the loader.
/ Help me compare these 4 tractors! #5
I took the time to research the BARE TRACTOR weights on TractorData.com. YOU DID NOT.
If you do not have hard data, do not question mine.
/ Help me compare these 4 tractors! #6
True. But tractor weight is the single most important factor in tractor field performance.
I have been following and making suggestions on your several previous threads regarding this tractor selections. Given the information you have posted this time, I suggest the HEAVIEST BARE WEIGHT TRACTOR will probably make you happier than the lighter tractors under consideration. ( This from a satisfied Kubota repeat customer.)
Your LS J2023 weighs 1,565 pounds bare tractor. With the 4,053 pound Branson, you WILL NOTICE A DIFFERENCE. Branson is also the right width for operating a 5' Rotary Cutter in the woods. If the Branson fits between trees, the R/C will follow.
True.
I have been following and making suggestions on your many previous posts regarding this tractor selections. Given the information you have posted this time, I suggest the HEAVIEST BARE WEIGHT TRACTOR will probably make you happier than the others under consideration. ( This from a satisfied Kubota repeat customer.)
I appreciate the suggestion, but are weight of the tractor can't be my sole consideration. There are more factors to consider, at least for me.
/ Help me compare these 4 tractors! #8
The web site says the Branson 3520 is 3600 lbs without loader.
They use a Bosch VE mechanical injection pump which is a common part. There is probably a small fuel consumption penalty vs electronic injection. But it's not noticeable- I go through about a gallon an hour working the 3725 hard with the PTO wood chipper which is what other people here with similar sized tractors report.
What don't you like about your current tractor?
I sold my current tractor. It was an LS J2023. Not heavy enough for what I need to do now. Good for jobs around the house, but that's about it. Light weight, not a lot of traction, narrow and tippy, and just not meant for the work I need to do now with the hunting property and food plots.
I personally would go with the LS. ;)
It's certainly my top contender. 39HP, 31 PTO HP, 2 sets of rear remotes, SSQA bucket, and 4 cylinder engine as opposed to 3 cylinder for all the rest. And I have good dealers in my area.
/ Help me compare these 4 tractors! #12
My buddy just bought a 3039. He loves it. I am a Kubota man all the way, but I would pick the 3039 out of that group. If one of the contenders were a Grand L, I would be partial to it due to my good experience with them. Having seen his 3039, I can say that it is sure a nice machine with lots of features and a solid looking build.
Since you've had good experience with LS, I see no reason not to go that way. Surely more tractor than the Kub and JD you're looking at. I'm not as familiar with Branson. Their popularity and dealer support in my locale is non-existent.
/ Help me compare these 4 tractors! #13
Unfortunately, it seems as though the majority of Branson dealers are short term. I may be way off with that statement, but from all that I have read, there are only a few long time Branson dealers.
That LS is a deluxe machine vs the economy models of the JD & Kubota. While the Branson is a good machine, it is currently short some of the features that the LS has. Parts will be available for the Branson, but you would have to look and double check for a dealer and I'm not sure that the possible headaches would be worth having the additional weight capabilities.
Olympus, good luck with your final decision.
Thanks. Both the Branson and LS 3039 can be viewed at the Murphy Brothers Trading website. Plenty of pics of both.
/ Help me compare these 4 tractors! #15
You don't really compare cost, so I'm not sure if thats an issue or not, but I'd go with either the Kubota or the Deere. Thats based on there reputation and long term and large dealer network. I think you would also be happier with an HST machine also.
All are going to be within a hundred dollars of each other. Right at the $15k mark.
LS has a very strong dealer network in my area. 3 very large dealers within an hour drive.
Actually I was able to talk to the dealer about the LS 3039 and got down to $14,800 for that tractor.
The JD and Kubota were both $15k even and that's the lowest the dealers would go. I think I've talked myself out of the Branson just because of limited dealer network, smaller scale brand size, etc. My wife says this tractor better last a lot longer than the 3 years I had my last one. So 10 years from now, what does the Branson brand look like compared to the other? I'm just not as confident in the Branson brand as any of the others.
/ Help me compare these 4 tractors! #18
I have an LS R3039H that I bought in July of 2013. It has exceeded my expectations and continues to do so. I had one minor warranty issue that was addressed quickly and efficiently by my dealer.
If the LS meets your needs, I would not hesitate to get one.
/ Help me compare these 4 tractors! #19
You have been posting and posting and posting threads on this selection, which is fine.
If the Branson is OUT, OK; move on.
Who can predict the future in one year, much less ten years? (New tractors may be battery powered in ten years.)
LS is the second heaviest of the four subject tractors. There is no question in my mind that LS is a quality brand. I have shopped them. Korean, like Branson.
Who knows the future in one year, much less ten years?
LS is the next heaviest of the four subject tractors.
I guess I can post as much as I want. There are still three other brands here. So moving on is what I'm doing....to the other three choices.
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2021 CATERPILLAR 315 EXCAVATOR (A62129)
2021 CATERPILLAR...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
