Common forklift hazards
/ Common forklift hazards #2
Take a forklift operator safety / certification class. Usually less than day in duration and well worth the time / expense.
/ Common forklift hazards #3
Situational awareness and a knowledge of physics is a good start. And this video should be a part of every forklift training program.
/ Common forklift hazards #4
I was the alternate forklift operator at the Machine Shop and enjoyed it...
I got that job because one of the guys parked the forklift with the forks up and someone walked into them... not good.
A lot is common sense... no riders, no horseplay, think before moving and as mentioned situationell awareness... being in a hurry serves no one and is ripe for accidents...
We would sometimes have to go out on the road for certain deliveries... one thing to operate on a smooth and level concrete surface and quite another with elevation changes...
/ Common forklift hazards #5
I worked in a big factory that used forklifts with baskets to hoist guys up to work on piping etc. Just a steel parts basket with 3' sides and I don't think we ever chained it down. It worked and never thought much of them sliding off, we just went slow. Until one day the mast tilted forward and a basket slid off with the guy in it. He got banged up a little because everything in factories are made of steel it seems.
That changed to snorklelifts and scissor lifts with all the tie downs and lanyards.
The operator really has to be on the ball if someone does go up in one. Tractors are more dangerous because of the radical movement with a little nudge on the controller.
/ Common forklift hazards #6
I was the operator for the baskets... slow and steady hand and repeated verbally each action to confirm...
The basket was chained to the lift... so no danger that way.
The same guy that left the forks up was too much of a jokester and didn't last long...
/ Common forklift hazards #7
I happen to be a fork lift instructor/ evaluator at work. Had to take a 3 day course for the certification. Most of it was learning how to teach :rolleyes:
Slow and easy is the best advice. Also keep the load centered and as low as possible to the ground. Avoid abrupt manuevers. When going up and down a hill, or loading ramp, keep your load on the uphill side. In other words, drive up the slope, back down the slope when a load is on the forks. Know and understand the lift capacity for the machine your operating as well. Safe lifting capacity is listed on a plaque on the machine. Should list 24" on center, sometimes list 36" on center as well as 48". Just depends on the size of the machine and length of the forks.
My small fork lift at work (5,000lb capacity) only lists 24" on center, but only has 48" long forks.
My big forklift (16,000lb capacity) lists 24", 36", and 48". That one has 8' long forks. I've had the back tires off the ground on it before lifting a 13,000lb piece of equipment. That will make you pucker :eek: But I also expected it to be questionable so we took steps to minimize movement and increase safety. We kept the lift at 6" max off the ground to move the equipment into the middle of the parking lot. Took about a foot ball field worth of movement to get the equipment turned to allow for loading. Then parked a backhoe on the back end of the forklift to keep it planted on the ground :) then lifted the piece of equipment just high enough for a tractor trailer to back under it.
/ Common forklift hazards #8
G'day Mate and welcome to TBN from Downunder.
x2. Everything that I learnt on my forklift course I have applied to operating the Front End Loader (FEL) of my tractor... especially when moving a load down a slope or incline.
So what, exactly, is a 2012 tractor?
Enjoy the site.
/ Common forklift hazards #9
Keep the load low and avoid turning and moving the load up and down at the same time. Know how long your forks are and how far they are sticking out the end of the pallet.
Doug in SW IA
/ Common forklift hazards #10
I too had certification for fork lift training (here on the farm). It was way cheaper than sending employees to classes for training and recertification
^^Good info^^
Here are some similar links:
  • Article
  • Type: Miscellaneous
Replies
0
Views
47
  • Article
Replies
0
Views
34
  • Article
  • Type: Construction
Replies
0
Views
186
