Ford 735 Loader Control Valve
/ Ford 735 Loader Control Valve #1
Tractor5000
Milford, MI
Ford 5000
I want to replace the control valve on my loader and have picked out a new Joystick controller.
The question I have is what is the pipe that goosenecks up and through the steel plate?
Is it a Power Beyond, or unloader? It appears to go into the arm of the loader and has a nipple on the inside of the arm.
This is the Joystick: 2 SPOOL 14 GPM PRINCE LVR JOYSTICK LOADER VALVE | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
This is a pic of the pipe I am talking about:
Thanks for your help.
/ Ford 735 Loader Control Valve #2
That pipe is the loader fluid return to tank. The hydraulic reservoir is the loader frame.
/ Ford 735 Loader Control Valve #3
What's the gpm of the pump.
14 may be too small.
What tractor is this on?
Is it using tractor hydraulics? Or the add-on front pump?
Is it feeding anything after the loader valve? 3ph or backhoe)
The pump is a front pump. 13 gpm
No backhoe or additional equipment.
The Tractor is a Ford 5000
/ Ford 735 Loader Control Valve #5
Mine is pretty similar the loader arms are the fluid resorvoir and the metal pipe from the valve to the arm should be the fluid return
/ Ford 735 Loader Control Valve #6
have same loader 21 gal min front pump.what joystick valve are you planning to use.
FORKLIFT (A56857)
FORKLIFT (A56857)
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
2005 International 4300 Hook Truck, VIN # 1HTMMAAM15H108569 (A61165)
2005 International...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
1761 (A58375)
1761 (A58375)
