Anyone R&R the electric motor on a HF concrete mixer?
   / Anyone R&R the electric motor on a HF concrete mixer? #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
I plan to use my HF mixer in the near future but I'm not very confident on either the size or longevity of it's electric motor.
Like the title says: Anyone remove and replace the electric motor on their HF concrete mixer?
- Any tips or tricks?
- Anyone know the frame size, HP or RPM of the OEM motor?
- Replace with same HP or go up?
- Replace with same RPM or go lower?
Thanks a bunch!
   / Anyone R&R the electric motor on a HF concrete mixer? #2
I have an old Montgomery Wards mixer from the 50s. I generally steal motors from old HVAC blowers when it needs a new one.
   / Anyone R&R the electric motor on a HF concrete mixer? #3
You could dnl the manual from their site - they show two, one's 1-1/4 cu ft the other's 3-1/2 cu ft. Larger one's motor says 1820 rpm, smaller one's 1192 rpm. Gotta LOVE "standardization" :rolleyes: No mention of frame size, etc, looks like a basic slotted mount - Typical HF stuff, no real details.
IME, I'd wait til SOMETHING breaks; might be any # of OTHER under-built parts, including the drive gear... Steve
   / Anyone R&R the electric motor on a HF concrete mixer? #4
I'd wait until something breads as well - might be cheaper to replace the mixer than repair it.
   / Anyone R&R the electric motor on a HF concrete mixer? #5
   / Anyone R&R the electric motor on a HF concrete mixer? #6
Thanks a bunch!
Don't know what mixer you have, but I wouldn't worry about it if it is the 3 1/2 cu.ft. one. I had mine and mixed all the mortar for cement blocks for a 30x50' basement, sidewalks of maybe 5 yards of concrete. Mixed a large storm shelter with footings and floor for a garage, maybe 20 +yards of concrete. I never worried about it and is still going strong.
If you do change anything go with the same RPM, same HP. It works great.
   / Anyone R&R the electric motor on a HF concrete mixer? #7
I would suggest pulling the electric motor, clean it up and oil the bearings with 3 in 1 oil. Write the information down on the data plate so you know what you might need to replace it later.
I did have my small wheel barrow style mixer die in the middle of a pour a few weeks ago. Working by myself I was able to pull the motor and clean it up and oil it. Put it back on and it has worked fine for another three pallets of sacks.
   / Anyone R&R the electric motor on a HF concrete mixer? #8
Only time I have had any trouble with the motor in mine was when I got in a hurry and pushed the batch sizes, it would overheat trying to start and trip the thermal protection. If I gave it a hand starting, it was fine.
I tried to mix two 80lb bags once. Once. Upon hitting the start button, it fell over, right on the pad I was pouring. 160 lbs of wet concrete plus the weight of the mixer. I had to use my tractor to lift and and ask my wife to drop the FEL because it was out of balance, very tippy.
I only do one bag at a time now. Maybe that will let the motor last longer, dunno.
   / Anyone R&R the electric motor on a HF concrete mixer? #10
Although My mixer is not a Harbor Freight brand , it is a little bigger than their 3.5 c.f model , I replaced the motor on it with a H.F. motor , ( 1/2 HP General Purpose Electric Motor ) and it still works Great . Just ran 14 80# bags of the redi mix through it this morning . 2 bags at a time , some water first , then 1 bag , allowed to mix , 2nd bag , then add water to get the mix I wanted and dump in bucket of tractor . 3 batches to a tractor bucket , then out into the field and shoveled into a pump house to keep the ground squirrels from digging in .
Mine looks like this : hqdefault.jpg
Brother has the 3.5 c.f. H.F. model that he got in a trade with Our other brother . We have used it a couple of times and I like the way it works with the multiple positions it can be locked in . I don't think you would have any issue's by getting the same motor I used and bolting it on . RPM is almost the same , pulley would likely swap right over and guessing the bolt pattern is also close enough , since they are slotted on the mounting plate .
Fred H.
RV Hitch (A50121)
RV Hitch (A50121)
2018 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2018 JLG 2632ES...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2007 Mazda CX-9 AWD SUV (A55758)
2007 Mazda CX-9...
UNUSED (1) 3500# IDLER DROP AXLE (A54756)
UNUSED (1) 3500#...
