Log in the grill
/ Log in the grill #1
jabelding
Gold Member
Maine
2014 Kioti CK35 2015 CS2410
Bush hogging around my field last week without my loader on, I heard a crunch up front so I stopped to take a look and found a nice 2"dia branch shoved up through the plastic shroud below the hood into my battery. Luckily I stopped a soon as I heard it and no major damage done just a broken shroud that I can replace for $70. So I decided to add some expanded steel to the front guard went with larger mesh on top for the headlights. It should stop most everything now. Online metals has a great price on expanded steel ~8bucks for a 2x2 piece.
/ Log in the grill #3
Every little bit help... :thumbsup:
/ Log in the grill #4
My wife was out cutting some heavy brush the other day with our Kioti and came back to the house saying the oil light was on.
I doubted the was an oil supply issue, most likely a stick knocked the wire off the sensor. I get out there and find that a stick / tree trunk got up into the back side of the rad area and knocked all of the blades off the fan. Luckily the damage to the rad was minimal and nothing was leaking.
I've got a fan on order, a dealer that's 2 hours away had one on hand and shipped it out right away. No idea why the oil light was on, I am wondering if it's a combination oil pressure / oil temperature light as I know the engine was hot when she shut it down. Luckily I have a cab so she just used the cab heater to cool the engine done before turning it off.
Jason
/ Log in the grill #5
Jason
/ Log in the grill #6
View attachment 518800 View attachment 518801
Nice job, I'm interested on the way you secured the hydraulic lines to the loader frame. Is it factory home built? I just use an elastic cord.
/ Log in the grill #8
OUCH on the log jam ! Nice fabrication work ! I always have the loader on when i use the brush hog. Yes it can limit my turn radius but it has saved me numerous times from hitting stumps and bigger items. I keep it about 6 inches off the ground.
/ Log in the grill #9
jabelding - Great work ! looks like you found a perfect match for the paint . What was it ? We bought a can of touch-up-paint when the 2004 CK30 was new . Had some touch-up to do - found the never used can and it sprayed out brown !
/ Log in the grill
Chuck
I used some standard hose clamps (the green plastic pieces from surplus center) 1/4 IN TWO WIRE DUAL HYDRAULIC HOSE CLAMP | Hose Clamps | Hydraulic Hose and Hose Assemblies | Hydraulics | www.surpluscenter.com
then tapped the loader arm for the bolts. On my QD bracket I fabricated up the bracket and painted it with Kioti new orange Spray bomb. Same paint I used on the front grill. It is expensive from the dealer $20 but it is very good quality paint and seems to be an exact match.
/ Log in the grill #11
View attachment 518857 Its a simple bracket, 3/16" steel, welded on to the crossmember with two holes drilled to hold the hose ends.
/ Log in the grill #12
Rabb
I
t
s
Rabbits li
ke a low front
bucket
/ Log in the grill #13
Did the same thing on my old L3400 even with the loader on.
Also had a stick take out the oil filter as well. Seen the oil spewing and shut her down before lost pressure.
Now my new to me but used MX5100 came to me with a hole in the plastic from a stick.
I have a piece of perforated stainless Ive been meaning to get installed.
/ Log in the grill #15
My DK40 doesn't have a FEL or a grill guard. The headlights on that model are very vulnerable and cost $400 plus. I've seen several used DK40's for sale that had the same busted HL's as mine.
That expanded metal fix is logical & cheap protection against branches that are always out there, if you do rough, non-field work. I sure don't see myself bush hogging my "pasture" with a FEL bucket 6" off the ground! I'd be constantly jammed into a contour or laying down a years growth before I got to it.
My DK HL's are much like the Kubota version which, thanks to higher sales? can be bought from Asia for $112. I think they can be made to retained in my HL spot where mine are fuggly from being epoxied back together.
Ground clearance has kept me from bottom brush problems.
/ Log in the grill #16
I did the same thing to my DK40SE HST last year.
/ Log in the grill #17
I've moved some big rocks but I wrap chain and drag them.
/ Log in the grill #18
I've always been concerned about taking a hit through the radiator but so far it ain't happened, no extra protection.:eek: I know that I'm living life on the edge, but no welder (first had to get a garage; welder is on my list).
Anyone know about a hood guard? Both my B7800 and NX5510 have taken hits on their hoods! Don't ask.:laughing:
Xfaxman, my B7800 took a salmon berry cane right up through the middle frame channel, a very small spot, and knocked off my hydraulic return line, catching the rubber and slipping it off the pipe. The angle had to be perfect. I'd horrify folks as to how I've operated my B7800 through the brush; but only had this and a fuel petcock break in it all.
/ Log in the grill #19
Jason
Good judgement. She sounds like a keeper.
/ Log in the grill #20
So I am not the only one who said, that is nice on the hose setup.
Grill is also nice but the hose retainer meant the most to me for I am using bungee cord also.
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
2015 Ford F-350 Auto Crane Service Truck (A61573)
2015 Ford F-350...
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
