Loader Brand new BX2380 Front End Loader Issue/Damage
   / Brand new BX2380 Front End Loader Issue/Damage #51
Put it in Float, although I'm not sure how that will work with that hydraulic manifold thingy disconnected.
Putting it in float will do nothing once you disconnect the hydraulic manifold. I just suggested moving the levers to get the pressure out of the lines so it will stop leaking and perhaps he can muscle it around and get loader off the tractor.
Aaron Z
   / Brand new BX2380 Front End Loader Issue/Damage #52
Any updates???? I know I had a heckuva time hooking the loader back up to my BX1870 after mowing earlier this year.I almost messed up,but after about 45 minutes I got it hooked up. I haven't removed it since.....
   / Brand new BX2380 Front End Loader Issue/Damage #53
For gawd sake stop screwing with it ! On such a new machine have the dealer get it squared away AND show you how to get it on and off correctly. My guess is there is not much damage beyond cosmetic scrapes, etc. -- that is if you stop now before you create worse problems. For one thing, I know we all hate to ever do this, but it is far cheaper to hire someone to do the one mowing for you than to fix all you can break by continued attempts at moving the loader.
   / Brand new BX2380 Front End Loader Issue/Damage #54
As a 6+year BX1860 owner (and I realize that the newer BX's have easy-on/easy-off FELs), one thing I have learned is NEVER move the FEL joystick up and down (raising or lowering the boom) when unmounting or remounting the FEL. ONLY use bucket curl (left and right joystick movement) to take the FEL off or put it back on. Once you use the raise/lower modes of the FEL control you are changing the basic geometry of how the engineers intended it should all work.
So, place the bucket down flat/level on the ground in a "neutral lift" position (that is, the bucket weight is off the tractor, and the FEL is not trying to pick the front of the tractor up), increase RPM's a bit, curl the bucket forward which unloads the FEL mounting pins, pull the pins out and drop them in their store holes, and then curl the bucket back. The FEL arms will disengage their mounts, and move both higher *and* forward of the tractor slightly. Now *slowly* and *carefully* reverse the tractor (in low range), moving backwards away from the FEL about 4". DO NOT GO ANY FARTHER OR ANY FASTER, or you can end up trying to drag the FEL by the hydraulic hoses -- which is not good any way you look at it. Now shut the engine off (see note 1 below), and disconnect the hydraulic quick-connects. With the tractor backed away just 4" or so from the FEL it's a lot easier to get to all of the QC's.
A few more hints...
1) After mechanically dismounting the FEL, but before disconnecting the hydraulic hoses, turn the engine off, and then move the joystick "circularly" (hitting all modes of the spool valves) a few times. This will release residual hydraulic pressure in the various cylinders of the FEL, which will make disconnecting and later reconnecting of the hydraulic hoses much, much easier. Once the pressure is off all of the cylinders (you will note that the FEL stops "settling" when this process is complete), lock the joystick in place using the little locking lever under the joystick pivot point. This will keep the pressure off the quick disconnects on the tractor if you inadvertently hit the joystick.
2) It of course helps immensely to have the tractor and FEL on level terms when mounting/dismounting -- e.g., a garage floor slab is optimum. So, don't take the FEL off on a hillside, you will have tons of trouble remounting it. Don't take the FEL off in 3" of mud, you will have tons of trouble remounting it.
3) The hose-end hydraulic couplers on the FEL may drip a little bit, especially as the temperature changes in the FEL storage location. I put the bundle of disconnected hydraulic hose couplers in a large ziploc bag along with a wad of industrial paper towels. After six months and a dozen or so connects/disconnects the towels are a bit gross and I start fresh again.
4) In certain circumstances, especially after a failed FEL mounting attempt, you may notice that one of the FEL mounting arms is positioned more forward than the other. This makes mounting the FEL impossible. DO NOT PANIC. These mounting arms are on the same hydraulic circuit, so simply get off the tractor and push/pull the arms back into place. However much forward one arm is moved, the other other will move backward the same amount, so you won't have far to move one to get them back in rough alignment.
5) Again, older BX models: don't forget to put the FEL kickstand down. ;)
ps
On level ground I can get the FEL off OR on in about 3 minutes including hydraulic hookups.
wrooster
   / Brand new BX2380 Front End Loader Issue/Damage #55
A few more hints...
ps
wrooster
Thanks for sharing, wrooster!
   / Brand new BX2380 Front End Loader Issue/Damage #57
Loader install / removal issues aren't limited to just the B series tractors. Problems can occur with L and M's as well. I've had FEL's on all my Kubotas and have learned over the years to just leave them installed. I have very little reason to remove them anyway and just take the QA bucket off when mowing. It is necessary evil though for those with front mount attachments like a dozer blade or snow thrower.
   / Brand new BX2380 Front End Loader Issue/Damage #58
The FEL's have been going on and off my two tractors literally hundreds of times over the last 15 years without any glitches. Parking the tractor and FEL on a flat, level surface helps a lot.
   / Brand new BX2380 Front End Loader Issue/Damage #59
mummer43,
How about an update about your situation? We haven't heard from you since June 24th. Are you back in business?
   / Brand new BX2380 Front End Loader Issue/Damage #60
mummer43,
I felt so bad for this guy. Probably can't talk about it . I remember reading it and felt my face getting red for him.
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
