LX277 drive belt loose
   / LX277 drive belt loose #1
phoogles
charlottesville, va
LX 277
I replaced all of the pulleys, the deck belt and now just replaced the belt that goes from the PTO clutch to the double deck pulley in the back of the deck (i *think* that's called the drive belt).
The PTO is engaging properly but the belt slips after a few yards of mowing. It's on correctly before mowing. I read on a site that it could be the idler arm bushing is worn. That's cheap enough to replace but I'd like some feedback if that sounds like the problem.
The belt was on tight but when i look after it slips, the double deck pulley in the back has moved forward, loosening the belt.
Any input would be greatly appreciated!
Thanks!
It's part 46 on the lx277 schematic
I'm not sure how to add pictures
   / LX277 drive belt loose #2
48C deck? I would refer to it as the primary deck belt. Bushings for the tensioner will usually get to the point to where they won't allow the arm to move freely. It all has to pivot freely to work well. A bugger to wrestle off and clean up. But as you said the bushings are cheap. Other issues?
   / LX277 drive belt loose #3
Thanks!
You say the pulley moves forward, is the tension arm placed correctly in the notch in the deck housing. Are you sure the belt for the pto is slipping and not the deck belt, if you just changed the pulleys make sure they are the right diameter. Did you have any issues with the belt slipping before you replaced the parts?
   / LX277 drive belt loose #4
Agree - Is lever locked in notch?
Also, did you fit the double pulley the right way up? The two sheaves are different diameter. (Smaller on top, except the 42"C deck)
Which deck do you have??
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
KLEIN TOOLBOX (A50854)
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A49461)
2015 JLG G12-55A...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
