XR4150 Loader Damage?
/ XR4150 Loader Damage? #1
CenCalLS
Member
Central, CA
LS4150H
Has this been an issue for anyone else? I wish I had a clue how I bent them but I really don't. I'm guessing while using my grapple a few weeks ago but I surely would have noticed it before now. I have recently used the auger for several holes but the most damage it to the side opposite the right offset. Dealer is trying to get me a price and availability to replace all four.
/ XR4150 Loader Damage? #2
I'm not seeing any cracked paint or stress lines. How does the the bucket or grapple 'sit' when raised? Is there an angle to one side?
/ XR4150 Loader Damage? #4
I would remove one and take it to a metal fabrication shop and have them make a set . Looks easy enough to replace by the diagram above
/ XR4150 Loader Damage? #5
Several LS members have bent these dog bone shaped brackets /arms. They are a weak point that can bend from either back dragging with the bucket tilted too vertical or running into an immovable object such as trying to push a tree over with the bucket. There are many links, here's one I found.
http://www.tractorbynet.com/forums/ls-tractor-owning-operating/314457-bending-metal-loader-2.html
I remember seeing another members replacement reinforced dog bones that had an extra vertical piece of heavy bar stock welded on for extra strength to prevent bending but couldn't find that link. If your loader is less than a year old they should be covered under warranty.
Its not just LS loaders, Mahindra and John Deere owners have bent the dog legs too. I think the loaders are made by Ameriquip but not sure.
No, they both sit square to the loader quick mount. George posted a link and it seems I'm not alone having this issue. Guess I'd rather have the "dog bones" bend than do mount or ram damage.
Thanks George, good info and great link. My dealer has another set coming and I'm going to research the pros and cons of beefing them up. Hate to do other damage to the loader further up. Appreciate everyone's replys...
/ XR4150 Loader Damage? #8
Correction... I should have said dog "leg" instead of bone which is more what they look like. I had just given my dogs some bones when I replied earlier.
/ XR4150 Loader Damage? #9
hahahaha I do that often when it comes to my dogs and golfing, Ever played a dog bone left hole? LOL
/ XR4150 Loader Damage? #10
/ XR4150 Loader Damage? #13
Rust-Oleum Professional Safety Blue 7524 Home Depot or Lowes or ACE should carry it. It is what I call "implement close" to factory..LOL
/ XR4150 Loader Damage? #14
I reckon that the 'dog leg' brackets purposely serve as a sacrificial weak-point for when the FEL is (inadvertently, of course) over-stressed. [None of us would ever abuse our FEL, would we? :D]
Why else would these parts consistently be manufactured and installed as an non-reinforced bar of steel?
My 300CX has the same non-reinforced bars.
I know what you mean, by beefing it up I kinda feel like I'm putting in a bigger fuse:rolleyes:
/ XR4150 Loader Damage? #18
My local farm and home store carries a "Ford Blue" tractor paint. Is that the closest to LS blue? They also carry a New Holland blue.
/ XR4150 Loader Damage? #19
I think there is several options for "close" blue colors out there but i do not think Ford blue or New Holland is the closest.
I've seen other use these options with successful results.
Rust-Oleum Sail blue (very close)
Krylon Safety blue
NAPA custom mixed spray cans. (if you NAPA has a paint department, they can make an exact match)
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
Front Tank Bracket (A64126)
Front Tank Bracket...
(2) Caterpillar Skidsteer Tires (A66408)
(2) Caterpillar...
