Sickle Bar Mower
/ Sickle Bar Mower #1
Matthew27808
BATH
1998 New Holland, 1725 , 1981 Long 510
I have a John Deere #5 sickle bar mower for mowing ditch banks. I'm thinking of changing the wood pitman arm with a aluminium tube and adding a slip clucth on the PTO. Any thoughts on this subject. Thanks
/ Sickle Bar Mower #2
My inquiring mind wants to know............why? :confused:
Part Number: Z9298H
Part Price: 23.61 USD
On Hand: 0 Check Other Stores
Description: Pitman Arm - MOWER PITMAN
Package Quantity:
1
Alternative Part
A-Z9298H Pitman - PITMAN WOOD - 20.89 USD
/ Sickle Bar Mower #3
The spruce pitman is intended to shear asap when you lock up the sickle bar. This can save the knives (riveted) and the guards (rusted bolts). Also when you engage the pto with the bar elevated by mistake. Take you chances with the slip clutch and aluminum will fail from fatigue.
So buy a lot of tubing and carry spare bars, knives, guards and tubes with you. It will look pretty, though !
/ Sickle Bar Mower #4
Yep! Dump the green paint and buy a NH or IH. Eliminate the pitman stick completely. They are only good for level, even fields with no rocks or mounds - situations very few of us have.
My brother on the farm I grew up on has a JD 37 and an IH 1100. He doesn't use them in the field anymore as he has moved onto mower conditioners. Even though he bleeds green he would give me the JD but he would not part with the 1100 which is still used for ditches and trimming.
Growing up we and our neighbors tried many things to make a stronger pitman stick to no avail. This was on #5's, #7's, #9's and then 37s. The solution was to change color.
/ Sickle Bar Mower
Yes, I guess this sickle mower I have wasn't meant to cut the things I cut. I just need to break down and buy a more modern mower.
/ Sickle Bar Mower #7
I had a 1948 Farmall Cub with an underbelly sickle bar mower. The original wood pitman arm was on it and it finally rotted and broke on me. It was made with some hardwood, oak I think from the looks of it so I replaced it with a piece of red oak that I matched up, sawed and drilled. Worked great. I like wood.
/ Sickle Bar Mower #8
The number 5 came while a PTO shaft that had a slip clutch in it. Big spring arrangement with serrated teeth.
/ Sickle Bar Mower #9
Absolutely true! Wood has a natural resiliency and will outlast many "modern" materials.
/ Sickle Bar Mower
I have a John Deere #5 sickle bar mower for mowing ditch banks. I'm thinking of changing the wood pitman arm with a aluminium tube and adding a slip clutch on the PTO. Any thoughts on this subject. Thanks
I couldn't find anyone that carried a pitman arm. Tractor supply or Agri supply. So I bought a hickory wheel barrow handle and made one. So far its working.
/ Sickle Bar Mower #11
DA Hochstetler in Topeka, IN sells them. They will ship anywhere.
/ Sickle Bar Mower #12
JD still lists them, Z9298H is the part number. Should be a stock order delivered to the local dealer in a couple of days. Price...$23.61.
/ Sickle Bar Mower #13
Pitman sticks protect cast iron components inside the wobble box or chain drive. The son had his wobble shaft replaced with a steel one designed by Mast Engineering, because when the pitman didn't break it did. His old binder is now capable of cutting down small trees.
/ Sickle Bar Mower #14
Mine cuts down up to 3" saplings without all that work. Don't waste your time on a pitman stick system.
Unverferth 632 (A64119)
Unverferth 632...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2018 International HX620 Quint Dump (A62613)
2018 International...
2015 Freightliner (A64119)
2015 Freightliner...
BUNDLE OF 8" - 10" I-BEAM UP TO 9' & (2) 2" & 6" (A64280)
BUNDLE OF 8" - 10"...
2013 Bomag BM-211D Single Drum Vibratory Soil Compactor (A61572)
2013 Bomag BM-211D...
