Bias Ply vs Radial
/ Bias Ply vs Radial #1
rockinbbar
Gold Member
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
I use my 100hp tractor for shredding in bad brush country with lots of thorns and hazards.
Into my 3rd season now on a tractor I bought new with standard Continental ag tires. I suppose they are 8-10 ply tires.
Was taking a shredder wheel for new rubber today and the company also sells tractor tires.
They sell some 20 ply bias tires.
Those appeal to me because of their thickness in what I do with the tractor.
Most of my projects are reasonably close, so I road my tractor and shredder.
Is there any reason I couldn't use these tires?
Tractor isn't a hot-rod. Usually drive at 18mph on highway.
Thank you for your input.
/ Bias Ply vs Radial #2
I have been researching tractor tires since I'm almost ready to replace mine. From what I have learned, radial tires have a little better ride and grip. Bias ply tires tend to handle higher weight better, possibly more puncture resistant, and are generally priced less than a comparable radial.
I will most likely go with radials for the better ride.
/ Bias Ply vs Radial #3
In a word...no. I purchased 16" fronts for my 4610 SU from Gensco. I think they are 18 ply. I am so pleased with them when I replace my rears I'm going to go with their 20 ply rears. Not one flat since putting on those fronts. Before that I was repairing flats on a regular and reoccurring basis when brush hoging. I believe you will be pleased with the results.
/ Bias Ply vs Radial #4
Going back to when passenger car radials came to the states,the factory rep that trained us said radials'big advantages were traction (longer foot print) and less friction (resulting in less heat). Unless manufacture made a good case for radial,I wouldn't spend extra on 10+ply tires. I see no way they could improve ride.
That's where I was today. Gensco in Wharton, TX.
Actually got to see and lay hands on the tires. They have some 14 ply radials and the 20 ply bias ply tires.
Still kinda swinging between the two.
/ Bias Ply vs Radial #6
radials big advantages were traction
I have both, there's NO question in my mind that it's true...
BUT, to get all that extra traction, you need to air down the ties a bit, and they should not be loaded, although they still are better "traction wise" even if you don't...
SR
You guys think there would be any downside to running the bias tires down the highway at 18mph?
/ Bias Ply vs Radial #10
Rough ride and they wear out faster...
I guess I never considered ride when roading. It's pretty smooth compared to the rough field which I just finished mowing.
I know people that tow and road smaller tractors and the tread is gone very quick. 100 hp and bat wing requires a heavy trailer but I would use a trailer rather than roading on expensive tires. I believe savings on tires would more than offset cost of owning the trailer. Most trailers I've sold brought close to what I paid years earlier.
I've got a 35' gooseneck that can carry my big tractor and 15' batwing. I don't use it much unless the job is quite far from me. Say the job is 30 miles away... I can drive my tractor there in an hour and a half. If I were to hook up, load my tractor, chain it, make the drive, then unchain, unload, shred, and do the whole process again, it just makes sense from a time, $$ and work standpoint to just drive. Especially if I'll be on the same ranch a few days.
My 45hp tractor and 12' batwing, I use the trailer to transport. But, I have a minimum charge to cover the time.
/ Bias Ply vs Radial #12
I just noticed where you are located. Much of your trip is probably on non-paved road. Around here everything is paved,otherwise you can't travel it during wet weather. Make's a difference in tire wear. You have to watch for stickers and stobs,we worry about what has been dumped or forgotten in high weeds. A little off topic but as a contract mower you might want to file it with your good things to know. I was mowing a neighbors pasture that had laid out for two years when he drove into pasture and got out of his truck where I had made the last round. As I approached him,he hit the ground and was being dragged toward me. I thank God and those that taught me to operate farm machinery that I emediatly killed the engine without clutching or disingauging mower. His foot was tangled in round bale twine the mower picked up. Older fellow was bunged up and off his feet for weeks. He only had medicare and no supliment,I had coverage on my place but carried no insurance for work off my ranch for wages. Everyone involved was relieved when I found that coverage extended to other parties with whom I bartered work or produced items. Everybody started picking up old twine after that. There had already been incidents where livestock got tangled up and half the ranchers had twine wrapped around driveshafts on their trucks.
/ Bias Ply vs Radial #13
SR
My opinion and experience also.
As to always trailering a tractor, not always reasonable. Take a person using one and say there is two miles between the fields they are working, you going to take 10 to 15 minutes to load and chain down it and then same time to unchain and unload when you could drive it those two miles in 5 minutes? Not sure how safe it is to haul tractor with a 10 or wider foot implement either, you often see the farmer have to pull tractor onto s shoulder for cars to pass. Rather not do that meeting a car when running even 40 miles an hour with truck and trailer. It also requires an area to load and unload an often there is not such an area at a field. Do agree when reasonable to hauling is good.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
