Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #1
GeorgeSB
Colorado Springs, CO
Kioti DK35
Fuel cap and well weaknesses. A dangerous situation by design, dangerous for the tractor's engine.
Kioti DK35, early 2003 build.
I use the term, "conspiracy" to mean that one design weakness we might get away with but when combined with another and another and add environmental factors and even operator error(s), we can lose the tractor, tractor's engine or cost us dearly.
I'll be up front and not hide anything about the situation. Unfortunately I don't have a protective storage for my tractor, she sits outdoors.
This situation I'm about to describe could occur to any tractor operating or caught in weather with this Kioti design.
I love my Kioti tractor. She's served me very well all these years. She's saved lives. She's pulled cars out of snow drifts and brought mothers and children home to safety when otherwise they would have been trapped in the horrible winter storms. She's made easy work out of large tasks. I don't know how we ever lived without this tractor. I use her quite often. I've got somewhere around 650 + hours (not sure because the cheaply made with plastic part, tachometer cable was broken for a time. Another weak design for another story.)
The Kioti design is generally robust. The engine is strong and many aspects of the design are very forgiving. But I've run across some really weak areas of the design. Some of these weaknesses floor me. I don't think Kioti should have been so cheap? I don't know how else to put it.
I want to speak to just one here. The fuel filling spout, protection, and overflow. Clean and water-free fuel is paramount for a fuel injected diesel motor. Everyone knows. But Kioti design engineers/production cost control people blew it IMHO.
On my Kioti DK35 tractor there is a fuel spout on top of the tractor. I find it difficult to refill with a 5 gallon container of fuel. There isn't an easy way. I have a spout that works quite well. But one must lift the 5 gallons on top of the machine and balance my feet on a tire or something to get high enough to tip the container. But that's not the concern. I'm certain there are many clever ways around this. And if you have a fuel container or a pump, it's hardly worth mentioning. For a small operator like myself it's an inconvenience at most. This isn't the issue I'm going to address.
The fuel filling spout has a cap. The cap is surrounded by a well with a drain. The cap and well are covered with a lid. Here's the problems. The problems can conspire to do harm to your tractor.
The lid is extremely cheaply made and flimsy and of a plastic that deteriorates in the sun and is very vulnerable to wind. In some environments it is totally inadequate. What we have here in high plains Colorado is ample sun and constant wind. I've gone through several lids now. The lid is a very weak design. Crazy weak design. There is also no fastener to hold the lid down against strong winds. It just flops down by gravity into position. The lid also isn't sealed. Water from heavy rains can get past the lid and go down to where the fuel cap and well are sitting above the motor. Almost certainly, water will get past the lid in wind driven rain at times. If that lid should lift the rain gets in. If even a spec of debris is in there, water will gleefully get past the lid. If the lid lifts and breaks, which has happened to me twice now, there is no protection at all, be it marginal to begin with.
I've had a terrible situation where the fuel lid broke off and very heavy wind-driven rains fell onto the fuel spout cap. That would not be a problem by itself. But with the well surrounding the spout having a lip above the bottom of the fuel cap, the well can fill adequately in heavy rains to reach the height of the very bottom of the fuel cap when snugged down, then capillary action can draw water into the fuel tank. This can happen even with the fuel cap on properly and tightly. (the people I bought it from had it cross threaded when I bought it and could barely get it off. Accidental cross-threading could make the cap much more vulnerable to capillary action. This cap and thread could be better designed as well.) And it can happen with an in tact lid on. Just a few lifts of the lid by wind and wind-driven rain flows down past it.
Of course all of these weaknesses are exacerbated if any of the following apply:
Cross threaded cap
Cap that doesn't perfectly seal
Thread are no longer perfect
The tractor isn't pitched favorably for the well to drain quickly
Debris in the well drain
Heavy rains
High winds
Broken or missing fuel lid
Debris in the fuel lid interface to the tractor body
Others ...
One day my wife complained the tractor was hard to start. I had no idea what the problem was. I looked it into long enough to finally learn there was some water in the fuel. I had to tow it back to my garage. The repairs took a lot of work, research, labor, and perseverance. Fortunately for me I ended up having only had to replace the glow plugs. I ended up replacing the heater glow plugs after taking quite a bit of the fuel delivery system apart, draining and replacing fuel. My tractor was down a week or so. I was very worried I'd never recover the engine. But fortunately, the engine is robust, I got her going again. She's been serving flawlessly for some time since.
Here are the measures I've taken to prevent a recurrence. I tore out the rubber well that the fuel spout and cap sit in. If there is a fuel overflow while refueling, yes, it might get onto something, instead of neatly going down the overflow drain tube to the ground. But it's worth it! It is now extremely difficult for moisture, water, to stand at all in the area of the fuel cap. It's virtually impossible for water to stand high enough in any way to be drawn into the system from underneath the marginal cap. Also I'm no top of keeping the lid replaced as they break and fail over time. I've even covered the engine with plastic or other materials to keep heavy rains from pooling onto the fuel door lid. I am extremely careful to slowly start the cap threading and once i know it is correct then completely tighten her all the way down. I frequently visually check the area around the fuel cap for any standing water, right after rains.
I'm not going to mention the weak and short-lived fuel bowl "pot" that is talked about elsewhere. I just ordered a replacement. I don't think it has anything to do with the water issue.
I've not seen a recurrence of the problem since the repairs and changes. That is true in spite of heavy rains for many days and high winds as well. I also added frequent checks of the fuel pot for water potential or coloration. Will be more difficult with the new designed fuel pot that is milky colored. Darn!
I may at some point design and build a better fuel lid door with a latch and a water-tight seal in a manner that should and could have been included in the original design by Kioti. I also feel rather "forced" into finding the cash (I'm retired) to self-build a garage just for this tractor. She seems weak to the environment in numerous ways covered elsewhere (sun does a number on destroying all the plastic, the seats, the hydraulic lines. The wind drives dirt into the poorly designed shifter linkages and other moving parts, so we have to clean and lube quite often, etc.) . I may also study the fuel cap more carefully and if I don't think it is adequate, order a cap that seals better.
It's shortcomings like this the befuddle me in the Kioti design and build department. Taking short-cuts where so little effort and cost would be involved in a better way. I've seen a number of short-cuts now in the Kioti design, some affect safety, some affect longevity, some affect operations, some affect our backs. This is the disappointment of the Kioti. I have no idea if you'd find similar problems in other tractors, such as Kubota, Deere, Ford, New Holland, etc. This is the one and only tractor I've ever owned. I still love my Kioti. I've just had to learn and adapt and make some improvements of my own.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #2
If the well can catch fuel and direct it to an overflow tube down to the ground, why wouldn't water follow the same route and just be directed down to the ground?
Good question.
I'm not an "expert" and haven't done time-lapse photography studies, so here's speculation.
If the well was designed for a little fuel overflow and not heavy rains, there's a lot of options for pooling of water.
if the tractor is not on flat and level, ground, and we don't have perfectly flat ground, it could exacerbate pooling.
If the outflow is in any way dirty it could exacerbate.
If the inflow of water is very heavy....
All I know for certain is that it happened.
It's possible that the well wasn't to blame, of course.
That leaves me only to think that "somehow" the cap allowed water in on its own.
I don't know of another entry point for water, except for refilling with water in the new fuel or refilling in the rain or some such.
We didn't refill the tank.
It rained heavily and high winds for days before this failure mode.
I'm conjecturing with what I can observe.
Thanks for asking the logical question!
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #4
Any decent canvas shop could make you a cover for the center section from the grill to the PTO. Ask at your local boat shop for references.
My 2014 Kioti has a substantial metal door over the fuel filler. I use a 5 gallon plastic diesel can shaped like a cube, and I installed a flexible plastic fill line on it in place of the spout. I set it on the hood, pull out the fill line, and tip it on it's side with the line in the neck of the tank. It's a CARB-approved can, with a non-CARB-approved spout, but is unvented. It takes a few minutes to get the first four gallons out, then I hold and tip the can as needed. A good three-step stepstool would be needed if I were not 6'3. I know others who use racing fuel containers and/or siphon pumps.
An alternative would be to go to a race shop and see if they can help you either extend the neck of the tank or help you install a better cover. A good boat shop might also have a better cover.
Something like this: Amazon.com: Bully BBS-231 Black Bull Series Gas Door: Automotive
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #5
Well... Hawkeye beat me to it. I was re-reading the essay above and the same thought crossed my mind.
Firstly, these tractors are not designed to be stored outdoors in all weathers. None of the common colours are. Not without some rudimentary protection anyway.
I feel some personal responsibility may be called for and I think you're being a little harsh on the Koioti/Koreans here. They have provided a catch area and a drain pipe for any fluid that finds itself loose around the fuel cap.
If it's anything like the 'Green' or 'Orange' ones I've seen it will be 10-13mm ID and be more than capable of handling rain. It's a straight path to ground. Not even an "S" trap like under the kitchen sink.
Where I have seen the drain struggle is when debris has blocked the pipe.
You bought the tractor second-hand so do you know if the pipe was/is clean? Fuel spills of diesel cause the collection of oily dust/debris which eventually blocks the overflow pipe. At best, it restricts the flow.
The fuel cap is vented by design. The lid is there to protect it from direct water. The drain pipe is there to channel fluid (water/diesel) away from the console (electrics). Even a strip of Duct Tape will hold a fuel flap down.
The most common source of water in diesel fuel is from contaminated supply and, to a lesser extent, condensation. Is it possible you had a fill of diesel which was contaminated? Everyone answers "No" to this question, worldwide...
With regard to the Water Seperator - I have read the long thread elsewhere - I wonder if any of you Kioti owners have considered fitting a better quality unit from a JD or Kubota? They would be a direct replacement and have proven credentials in respect of the bowl, transparency and (JD at least) the Red Ring water indicator.
UV attacks the plastics. Outdoor storage exposes your machine to attack all day, every day.
Regards,
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #6
Holy Crap! I have to re-engineer things just about daily. Nothing is made with any care these days and after being thrown together they push it off the line onto the retail buyer's upcoming headache area. DO NOT buy a new tractor under any circumstances, or be prepared to be astounded by the junk we get thrown at us- and are EXPECTED to accept with no whining!
Example: I bought a brand new 2015 Husky 322T ride mower; nearly $6,000. The front transaxle had a palm of my hand sized silicone glob jammed in at the axle shaft! WHY?! Because at the factory the rocket scientist assembling the transaxle decided to pass the leaking like a sieve unit out the door to my retail dealer, so I could buy it and have it replaced under warranty. It NEVER should have left the factory to be delivered to a retail customer, but it was. SOP these days. Trip up and back to deliver and pickup the mower, time and gas wasted in both directions, 1 hour each way, TWO times. So at least 4 hours of my life wasted because of some idiot at a factory. AND then they reinstalled the brake cable routed wrong, chafed the belt and the cable. Now the spring tensioning the same cable is damaged and needs replacement, AND the 'new' replacement transaxle seems to be leaking too- AND it's off warranty, so if it needs another transaxle it will likely be at my expense. If I hadn't had the bad one to begin with maybe the current one would have failed during warranty and I'd now be replacing the first factory installed transaxle instead of the one that should never have left the shop winding my warranty clock down so that when I need a replacement I end having to pay for it! Getting my drift?....
Show us pics of the offending area/parts and we'll design and sign off on a better design and send you on your way.
As pointed out, you live in a high wind, and rain/snow belt.
Take further preventive measures to make up for the 'deficit' that you think is Kioti's responsibility.
I'd try a appropriately sized tuna can or coffee can or similar and place a rock on it or on the original fuel cap door to hold it closed, or similar. Or build or buy a shed, or carport or aircraft hangar or whatever to block the wind, rain, snow, and flying dust, dirt, etc.
Paint and hydraulic hoses deteriorating in the sun?! Ha! What doesn't. Get some Armor All, or similar and wax your tractor's hood, etc. Put a tarp over it and hold it down with rocks, stakes or bat guano!
Next!
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #7
My DK35se is a newer model. The fuel lid door is made of chrome plated steel. It is spring loaded to stay shut or open when fueling. The fuel cap has a gasket for sealing out water and debris. The well and drain work very well for containing any fuel spills and drains them harmlessly to the ground, but of course an occasional inspection for debris that may accumulate to stop up the drain would be in order. Perhaps the newer door and spring could be retrofitted to your older design?
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #8
Tarps are cheap, you can't blame Korea for your tractor deteriorating in the weather. If I didn't have a garage to keep mine in I would have at least built a pole shed or car port to protect my hero. With the way the UV's are now days nothing will last sitting out in it for years.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #9
I could never understand why anyone would spent thousands of dollars on a tractor and then not build in some protection for it. I often see machinery being used and then the operator just shuts it down and walk away. I know money is a factor in many of these cases but a tarp is cheep and a lot of times given away at Harbor Freight.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #10
Agrreee 100 percent on these last two posts. You can make a pretty nice Q hut from bent conduit and shrink tarp for a couple hundred clams.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #11
George, welcome to TBN. I enjoyed your post. As others have noted, Kioti now uses a fairly substantial spring loaded metal door to cover the fuel spout. I don't know if they are any worse than other manufacturers regarding the gymnastics necessary to add fuel. I find the cube shaped 5 gallon tanks work tolerably well though starting fueling without spilling is hard. At least it's diesel not gas!
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #12
Two years back, when we lived in Greenwich, we bought Deb's parents home...I got the brilliant idea to switch everything over to propane. I bought a 1000 gallon underground tank from Galway-Co-op, while working my son came by over and be did the digging for the tank for me... 17' x 5' x 5' and he accomplished this in about 5 to 6 hours with my JD 855 with a #7 backhoe. Tank was set in sand bed, and my good friend came over with his CK20HST Kioti. What a little beast of a tractor, absolutely amazing the lift capabilities, he handled sand like it was beads of styrofoam, my 855's 52 loader was straining to pick up 3/4 bucket. Even the capacitys on the 3 point hitch is double than mine... More than a little discouraged, but this little tractor a does more than just dig, mows, snowblower, everything we've asked it to do, just slower... And there's hardly any electronics, downside is parts be are getting harder to locate. Starts everytime, right now putting together a pull behind mower 52" wide to cut mowing time. I would like a newer tractor but then I don't.....
My only complaint would be hitting the relief wicked early when I dig with hoe other than that, maybe some green paint would keep me focused.....
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #13
I had to wait a few months to get my Kioti Den built. I hated leaving the tractor out in the weather those few months. It takes a slow toll on everything.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #15
You should see the arrangement on my B7800. One of the reasons why I finally got a tank and pump: stupid loader stabilizer bar interferes with refueling, horribly so (trying to keep a no-spill jug emptying is a practice in patience)! And then Kubota's fuel caps for this were crap. Had the thing blowing off when the tank was full and the tractor would get slammed down: I'd end up being bathed in diesel! Dealer told me they had a new design. Really? Why didn't they make this a mandatory swap-out? (I bought my tractor there, albeit used) And the new cap seems like it's going to start stripping out too.
If there are places where liquids can pool then look for a drain. I'm so used to having to deal with stuff like this: from washing machines (front loaders) to car sun roof drains. Had to install a revised condensation drain on my refrigerator (major manufacturer)- original one, duck bill, would clog and send water all over floors (some folks ended up with really expensive flooring repairs- hardwood floor got destroyed). Speaking of duck bills, I noticed my tractor has them for the AC drains: yup, another thing I need to keep an eye on! (NOTE: if you pinch/milk duck bills you can keep them from getting blocked.)
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #16
When I leave the tractor out in the rain, water collects in the low areas of the seat. Then when I climb on and sit down, my trousers get all wet and I feel very self conscious that others may think I've soiled myself.
I've thought about contacting the seat manufacturer. (It's about the third replacement seat and not OEM)
The tractor manufacturer should have engineered the seat mount to tip up when not in use. A serious design flaw. (But the dampened spring ride seat mount is delightful!) Mean while, I make due by spreading a canvas tarp over the operator's station when the tractor is parked out of doors, 'securely held on against any foreseeable breeze by four truckers bungees!
Oh Well, one does what one can. ;-)
eta
The all STEEL seat on the Fordson has never given a hint of trouble, though as age creeps up, long hours there become less appealing. ;-)
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #17
I had a 74 Thunderbird with a sun roof, and the drains stopped up. That was a mess on a rainy day. Got that fixed pretty easily, then the drive cable broke and the replacement had to come from France of all places. Yep 2 weeks with the sun roof blocked up. I vowed to never own another car with a sun roof. And I haven't. Of course they don't make them like that any more, they are moonroofs, and they seal entirely different. They actually seal against a rubber seal instead of leaking into what amounts to a trough and draining down the inside fenders of the rear wheels.
It is entirely stupid to cut a hole in the roof of your car. IMHO. :) And now that I am an old curmudgeon, I wouldn't have a sunroof or moonroof for all of the tea in China. If I want to shoot squirrels out of my roof, I will just ride in the back of my pickup truck. :D
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #18
I own an older series DK 40. After seeing the fuel and radiator acess lids blow open in the wind I epoxied large washers underneath to hold them. The fuel filler cap became loose from plastic distortion and I wrapped the male threads with teflon pipe tape a few years back-works fine now.
I respectfully request people try very hard to be even more respectful. I'm only sharing so others might know the risk and save themselves. This water fuel issue only applies to older Kioti models.
There are times, even for folks having a proper tractor shelter, that they are caught in the field in the rain. I'm only pointing out risks. I am trying very hard to be HELPUL here. Thank you all.
I've been checking after rain and the fuel door isn't stopping it. So rain water will get in if you are working/driving and caught in the rain.
IF you have this model/year (mine is a 2003 Kioti DK35), you'd be best served to make a few minor changes to the fuel door, cap, drain cup, drain, etc. Just to ensure no water gets in.
As far as water in the new fuel added. Sure that's possible, I agree absolutely! Just seems improbable in this particular case that it was water in the fuel added. The tractor never suffered water in fuel until immediately after a very heavy and quite unusual days of downpour and heavy winds. It was the day after the rains that this happened. Also, "Someone" left it out in the field. I cannot mention the name or I'll live in eternal damnation. LOL. I have already forgiven her, as it wasn't her fault. She didn't know. It's also possible that "someone" didn't tighten down the cap. When I bought it the first owner cross threaded the cap. It was difficult to remove. So all these factors exacerbate.
So, I think it's probable that rain is the source water and a combination of human error and design "weakness" now resolved by Kioti served to get water into the fuel. I should have run out to put the tarp on it. But I didn't know how very high the risks until it occurred. That's why I'm openly sharing. Making myself a target at the same time.
With respect to protection, a tarp, or garage, or something. Yes definitely on my list of chores. I will build one soon.
But all that said, my concerns/comments/ criticism stand. The flap is just flimsy as all get out. It's windy out here. And it gets blown open and so easily breaks or just pops right off.
I am not venting on Koreans, so please forgive me if it sounds that way. I respect all peoples. All countries. All nations. I've trained extensively with Koreans in Korean arts. I have great respect. Even all engineers I respect, I am one of them. I understand how management can force cost-saving measures upon engineering....
But there remains a number of design "weaknesses" that wouldn't have taken much to improve upon. I understand later models are better in most of the areas I call out in my "essays". Clearly the Kioti company agrees with me. So, I don't mind making improvements of my own for those areas of concern to try to catch up with the Kioti factory improvements.
For now, the quick fix is to keep replacing the door atop the fuel cap. Keep checking the fuel cap for proper closure. (I'm not the only one filling). And if there's weather, attempt to cover with tarp, etc.
I like the suggestions, over the criticisms. Please people!
One person here said on his DK40 that he improved both the cap and the cover. THAT'S great input! He apparently sees the same risks that I see. Thank you very much. That's one reason why I posted, to share ideas for improvements. His ideas are very good.
As far as shelling out thousands for a tractor and not being wise enough to build a shelter.
Everyone's circumstances be different. I was forced to downsize in an economic error after an extremely favorable situation to obtain the tractor used. I was caught in the economic downturn around 2008. But I actually didn't want the tractor but I was offered a no interest personal loan with very low payments. That's the only way I could afford one.
There isn't adequate room here on this property yet. I have no income at the present as I retired early. So having a building made is not in the cards. So I will build a proper shelter by hand, trying to save costs. Possibly a Q hut or something used are options but it must be snow and wind hardy. It's really much too windy here for a tarp to protect in weather. We normally have high winds rain, shine, or snow. I hope to build a proper garage however and dedicate it to the tractor. As I stated, it's on my list and has been for a long time. But due to life circumstances hasn't yet happened. I might just tarp it indefinitely. Now that I have more time, I'm catching up with all the "must do" on the virtual "list".
Thank you for recommending such.... It's clear that Kioti recognized the same issues that I have. The newer models have fixed it completely. Thank you for the post about your DK35se newer model, that was really helpful. It's great to know that Kioti does acknowledge the issues that I've found and pointed out in this forum, and made improvements to resolve them.
Again thank you for all the beneficial suggestions and idea and updates on the newer design and on inexpensive shelter ideas.
Thank you all. It's great to have a forum to safely share questions, make suggestions, and warn others with the same machines. That's why I'm here.
I will repeat this. All my concerns aside, this is a GREAT machine. I love it. I will baby it as best I possibly can. This Kioti has literally saved lives since I owned it. I've pulled families out during horrible blizzards and much more. It's a strange thing to admit but when I bought it, I had a feeling it would serve and possibly save people from hardship. It really came to pass. We had a terrible winter where I was living at 7500 feet elevation. The snow that winter, just shortly after I took ownership, was life-threatening if caught in it. I helped out a lot of folks. Me and the Kioti were out there in the weather, helping a lot of folks. I was out every single day for a couple months.
Lately, now that I have some time (I was so over booked during my early years of ownership) I've been working on my Kioti almost every day to ensure all the maintenance is up to snuff and all the shortfalls are addressed. I've upgraded to a Grammer seat. I've added mirrors. I've toughened up the front grill. I've added bright lighting front and back. I've done all the filter changes and fluids. And so forth. That's OK, I don't mind doing it. And I love to enjoy the results.
I love my Kioti tractor. I promise to take good care of her going forward. Sorry all if I wasn't clear about things in my original post on the subject.
/ Fuel cap and well weaknesses. Dangers for tractor's engine. Design flaws conspiracy. #20
I wonder if the new fuel door and a new cap would retrofit to your machine? If nothing else the weighting of your existing cap so the wind does not blow it open allowing the rain to get into the vent or even past the threads would help? As for the cross threading, I don't know if a new cap would help there or not. Perhaps a little judicial application of a triangular file on the tank threads might possible help, but you would need to analyze carefully and apply carefully.
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Year: 2014 Make: Ford Model: Transit Connect Vehicle Type: Van Mileage: Plate: Body Type: 4 Door (A59230)
Year: 2014 Make...
2021 CATERPILLAR GP30N STRAIGHT MAST FORKLIFT (A60429)
2021 CATERPILLAR...
