Storing tractor and implements outside or under a roof?
   / Storing tractor and implements outside or under a roof? #41
Lynn's barn is impressive, Very tidy. I like the log stack. Check this out, if you like logs and barns, as I do Norwegian Barn.jpg Norwegian Barn.jpg. Of coure you cant get your tractor in there.
ian
   / Storing tractor and implements outside or under a roof? #42
The land I purchased in Texas had Krum - silty clay. Drainage is very good and the soil dries out a little too fast for some things we intend to do... but, regarding storage of the tractor and implements and given the soil, would some good .80 (or higher) treated 6x6 lumber be fine in the ground with 10" of 1/2" stone in the wells and compacted with coarse gravel?
I see a lot of people fussing with getting poles in the ground and squared up and understand what they are doing, however, wouldn't it be easier to auger the adequate holes, put your base stone in, stand up the poles and put your base banding on, square corner to corner and compact the corners in place? Once done, the poles in the spans can be shimmied and compacted. I've seen it done this way and though it saved a ton of measuring and fussing with the placement. The base bands will hold the posts in place against your strings... does that make sense?
We're looking at a few different metal buildings here but the one I quoted above seems to be the best deal going. I have to call another person about the concrete. My first choice isn't getting good reviews from prior customers I've found. If all goes well, I'll have the driveway, equipment barn and a well drilled by the end of the year.
   / Storing tractor and implements outside or under a roof? #43
The only things outside at my house is the grass, trees and the animals that don't sneek into my barn somehow.
   / Storing tractor and implements outside or under a roof? #44
I have a place the cows can get in out of the weather and sun. For whatever reason they prefer to stand out in the weather.:confused3:
   / Storing tractor and implements outside or under a roof? #46
Tractor, mower, log splitter, atv are all inside the garage. Any time they aren't being used, they're under cover. Cars and trucks can stay outside. They come and go, but as far as I'm concerned, equipment is forever.
8065 (A55852)
8065 (A55852)
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
2013 International Bucket Truck (A55973)
2013 International...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
1974 Ford F600 Grain Truck (A55315)
1974 Ford F600...
