PICTURES ONLY thread
/ PICTURES ONLY thread #381
What a differance a day makes
/ PICTURES ONLY thread #383
Log splitting with our XR4046HC.
We don't burn a lot of wood, only in two outdoor fire pits. Fireplaces, in the ranch house, are direct vent gas units.
/ PICTURES ONLY thread #384
Not new pics, but from September when it was new. Still had the cardboard covering the floor, and plastic on the seat.
The Boss removing plant materials and landscaping bricks from the lower yard.
Looking forward to warmer, greener days.
/ PICTURES ONLY thread #385
Got a snow blower for my tractor. I wasn't really looking for one since my front QA snow plow is doing a great job plowing snow. While scanning the web the other day and I found a used older Lorenz 730 series double auger blower for sale at a price that was too good to be true. I know its an older model because 1) Newer models have paddles in the center of the augers that push snow into the fan and 2) it has a 3 blade fan and newer ones have either 4 or 6 blade. A brand new 7' double auger Lorenz with hyd. chute rotation sells for 5K and this one was less than 2K so I bought it. All the warning labels look new but the prev. owner always kept it garaged when not in use. Got it home last night and put in garage this morning. Pulled, cleaned, and lubed PTO shaft and U-joints. Replaced all shear bolts and installed spares in the holes provided. Serviced gearbox. Cleaned, lubed and adjusted chain. Cleaned and lubed chute rotating parts. Adjusted skid shoes. Sanded and primed rusty scratches and I'll repaint the whole thing this spring. I still have to install a flow restrictor in the chute rotation hose because it turns way too fast. Made some slight mods so it fits my quick hitch. Hooked it up and tested by backing into some snowbanks I have piled up and it works fine. Will try it on the next snow we get. Plus its an extra 700 lbs on the 3 pt so more weight for plowing. I've added a link to a new model of my blower.
84" Lorenz 3-Point Tractor Snow Blower Model 731
/ PICTURES ONLY thread #386
Nice! Who doesn't like a double edged weapon?
/ PICTURES ONLY thread #390
Not my tractor, my new toy on the tractors trailer.
Very nice. I also picked up a new toy with my tractors trailer back in November. Sorry, no pics of it on the trailer. Took it off and went for a ride after hauling it for almost 4 hours on the thruway.
/ PICTURES ONLY thread #393
This thread seems to have fallen into disfavor. Thought I'd revive it with a pic of our LS sitting in the driveway. Dropped the blade there to use the bar for pulling, and had just put the blade back on.
/ PICTURES ONLY thread #394
Thanks PJ. The LS Tractor Picture thread got hijacked for a while.
Here's mine.
/ PICTURES ONLY thread #395
Thought it might be fun (and helpful to others searching for LS info) to have a thread where every post has a picture of an LS tractor doing something. There are lots of threads with pictures, but there is a lot of "chatty" space between them.
The rule of this thread is... EVERY POST MUST HAVE A PICTURE !!! Even if you're responding to someone else's pic, you must include one yourself. Discussions on pics & such are welcome, but you still need to supply a pic (preferable a new one that we haven't seen yet) every time you post. LS only. Yes... you can still be chatty... you just have to add a pic! The tractor can be the focus of the pic, or even be in the background somewhere... doesn't matter as long as you supply a pic with an LS tractor.
I'll start... My LS R4041:
With a 72" rake
Making a mess in the clay
Using the Middle-Buster plow
When TSO started this Thread, 4+ years ago, the rules were simple.
Pic of an LS Tractor with every post.
Do we need to get TSO to 'splain it to you' Lucy?
/ PICTURES ONLY thread #398
Mowing the back yard.
/ PICTURES ONLY thread #399
When TSO started this thread he owned an LS.
Me moving some brush and trees.
/ PICTURES ONLY thread #400
Let's keep this going.
Here is a pict of my R3039H with box blade.
This is a fond memory of when it was new:thumbsup:
Reminds me I need to take some current photos!
INSPECTION (A65563)
INSPECTION (A65563)
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
