Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR?
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #1
GeorgeSB
Colorado Springs, CO
Kioti DK35
I don't see anywhere a proper Kioti designation of DK35CR. It is a real designation? I see DK35SE or DK35 only.
Can anyone help with this? (I have a 2003 Kioti DK35).
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #2
CR means "creeper", which are models with normal gearbox.
Thank you.
That was simple enough!
I have a "CR", I guess.
I don't have hydrostatic transmission. Just clutch that I depress to get between gears. So I must have the CR.
Seems odd on ebay that a grill would be listed for the Kioti DK35CR but not any other models. Are they different in the grill?
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #4
I think it's all the same, except the gearbox
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #5
Well there is a big difference between a DK35 and a DK35se. The DK35 is older, and has different styling and many other differences. I would suggest if you are ordering trim parts, to take care. I have never heard of a DK35CR, but I don't doubt it exists. There is a fair amount of parts interchangeability between a DK35 and the newer DK35se, but trim parts would not interchange. These tractors are sold worldwide, and I am sure there are specific regional models of Daedong tractors. A picture would be worth a bunch.
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #6
As a side note, does your tractor have creeper gears? Do you know what that means? How many gear ranges does your tractor have?
The tractor serial number would be helpful, and perhaps we could figure out the manufacture date.
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #7
The CR is the creeper speed gearset. The standard transmission was an 8 speed with F/R shuttle.
The creep speed gearset made it a 16 speed transmission.
They had them that you could buy already installed, believe it or not they also had it as a "dealer installed" option.
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #8
Interesting. What might those "creeper" speeds be used for?
My DK45s has a low low range that is so slow I can't imagine what it's good for. I did use Low-4 once to drag an old school bus (with flat tires) across a dirt field to its final resting place. Otherwise, I've never used the low range.
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #9
I have heard of people hand weeding crops by riding on the back of tractors in special fixtures and hand weeding of maybe tobacco plants. Another use might be for a trencher to go very slow as the trencher cuts thru rocks and such. You could also use it to get off and let a tractor follow you as you gathered up rocks or sticks out ahead of the tractor and throw them in the bucket. Then get back on. As slow as it would go, you would not be in much danger getting on and off. My hydro can go as slow as you want to go, but your foot needs to be on the hydro pedal. With a creeper gear, it doesn't require an operator. I suppose you could point it towards someones house you wanted to destroy, and leave the scene of the crime!.. But in reality, I think they are for vegatable picking and row crop work of some kind.
   / Kioti Model question. Looking on Ebay for parts, I see a Kioti DK35CR. What is CR? #10
You can go pretty slow with a hydro too.. I made this video some time ago.
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
Rotadairon RD100 III Rotary Soil Tiller Tractor Attachment (A55851)
Rotadairon RD100...
3410 (A47477)
3410 (A47477)
