Mowing Mahindra 4110 - 5' or 6' Rotary Cutter?
   / Mahindra 4110 - 5' or 6' Rotary Cutter? #41
The 1540 I tried ou before getting my 4110 felt a lot lighter to me, the extra weight is one reason I went with the 4110.
It is heavier than the 1540... I got it cheap lol
   / Mahindra 4110 - 5' or 6' Rotary Cutter? #42
The 4110 would probably handle a 7 foot cutter. I've cut some awfully big stuff with my 4110.
I have ran an 8 ft Woods Brush Hog type cutter. My 4110 needs weight if operating on hills. The engine more than enough to use the cutter. But, for whatever reason, didn't put a slip clutch on unit.. Clearing brush a breeze when I wind up 8 ft cutter, lots of torque. However, stalling out on stump or something else stops tractor dead. I believe responsible for breaking tooth on big power take off gear. Since cutter doesn't have any belts to slip, a clutch is a must i believe. I would be happy with a 7 ft. 8 is a little too big , have to be careful.
   / Mahindra 4110 - 5' or 6' Rotary Cutter? #43
Have an 8 foot Woods finish mower. Like it, handles great and cuts a lot.
Cheers...Coffeeman
   / Mahindra 4110 - 5' or 6' Rotary Cutter? #44
My son-in-law runs the bush hog on 1000 rpm, then runs the tractor at lower rpms. He killed the engine when he hit a hidden pile of dirt over the weekend. I cringed when it happened, hopefully no damage. I run it on the 540 rpm setting with more throttle to the engine.
The 4110 is a beast for its size, lots of power in that Daedong engine.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
EZGO (A50324)
EZGO (A50324)
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
