Storing tractor and implements outside or under a roof?
   / Storing tractor and implements outside or under a roof? #11
My tractors are in the dry. The Ford stays under roof in a shed along with the brush hog. The Workmaster stays in my father's converted metal RV garage. My implements stay outside except for the grapple. I'm in the process of freeing up some storage space in the barn now for my implements.
   / Storing tractor and implements outside or under a roof? #12
Everything is outside currently. Trying to get a barn built
   / Storing tractor and implements outside or under a roof? #13
Tractor is stored under a pole barn. Roof only no walls. Implements are under a suspended tarp. (rope between trees with tarp across in a tent like shape) Tarp does not lay on implements and is open all around for air flow.
I am in FL though so no long winter buried in snow. Just daily storms in the summer.
   / Storing tractor and implements outside or under a roof? #14
I store all my equipment in the barn.
The hay is in a different barn.
View attachment 516460View attachment 516463View attachment 516462View attachment 516461
Lynn, every time I see pics of your property, I get jealous. Just beautiful.
It looks like you have a combination of concrete and gravel in your equipment storage area. Correct? Is the gravel crusher run? I am going to put gravel in a dirt floor pole barn I use for equipment storage. I have debated in my mind about whether to use crusher run or maybe 3/4 clean gravel. I am thinking that if i use crusher run and wet it down a few times, it will pack nicely and work well. Any suggestions by you or others would be welcomed.
   / Storing tractor and implements outside or under a roof? #15
I would recommend against crusher run for inside use. I had it in my pole barn for a couple years. It was a dust storm every time I started something up. Fan would blow the dry dust around and make a mess of everything. Use washed gravel or, ideally, concrete.
   / Storing tractor and implements outside or under a roof? #16
My tractors and equipment are all inside my pole barn. Best money I've ever spent. Keeping things in a dry, dark location really slows down the aging process.
   / Storing tractor and implements outside or under a roof? #17
My tractor and a few implements live in a small enclosed, shown here during re-siding:
The rest of the implements are kept in a covered shed:
   / Storing tractor and implements outside or under a roof? #18
Thanks for the heads up on the crusher run Bspeedy. It makes sense that the dust would be problematic. I know concrete is the best option, but I don't spend a lot of time at the remote cabin so I'm having a hard time convincing myself to spend the $$$'s. That's always an option at a later date.
   / Storing tractor and implements outside or under a roof? #19
We are going to start with something like this and maybe close in the drive-through center later. Overall it will be 44' wide x 36' deep. The two 12' wide add-ons on each side will have concrete floors while the center will be just washed gravel. The center will be 20' wide. The guy quoted me $18k for all of it. Another $3,600 to enclose the ends with 12' rollups.
   / Storing tractor and implements outside or under a roof? #20
IMHO, the important thing is to keep the SUN off as much as possible. At least in moderate climates. That's what will rot your tires, crack your seat, and fade your paint.
So a shed, aluminum carport, even a ShelterLogic "tarp barn" works. What you definitely DO NOT want is to put a tarp over it where gobs of ground moisture will rise up into the inside of the tarp and everything under it, and cover it all with mold and mildew.
The other thing the sun eats are rubber hoses and seals - think bearings, hydraulic hoses, belts, etc. Consequently I store anything with moving parts inside if possible. Angle blade, box blade, landscape rake, etc. who cares if the paint fades.
My bushhog mower (came with the place) had water in the gearbox when I got it from being stored outside. If you can get them up off of wet dirt or grass it helps too to keep the rust down. I had a neighbor whose finish mower froze up on him because he left it set for about 6 years - it was rusted real bad underneath. The deck will last much longer if it doesn't rust.
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2021 Ford F250 (A55973)
2021 Ford F250...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2016 Mitsubishi Outlander SUV (A55853)
2016 Mitsubishi...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
