I bought the big one!!
/ I bought the big one!!
Good photo. Ya might consider adding bracing and expanded metal to your grill guard. View attachment 513314 It has really protected my grill and headlights when I get a little careless at the end of a long day.
hugs, brandi
Thanks for the info and photo Brandi, that is certainly a good idea, could avoid some cussing and calling yourself stupid by being careless. I finally got around to installing my fast hitch yesterday. I've never had one, did some head scratching, and had to do some adjusting to get it right and level on tractor and brush cutter. But it really makes hooking equipment up so much easier. Do you use your backhoe a lot? I could see where it would come in handy for land clearing. I forget what model your Mahindra is, 7060, 8060?
Ben
/ I bought the big one!! #22
Ben
Your welcome. My backhoe stays on 99% of the time. It only comes off for mowing the gully. My Mahindra is a 2007 ........6520 4WD.
hugs, Brandi
/ I bought the big one!! #24
What is the gearing on the M series?
My 8560 is a 12/12, really could use 4 more in Low and Med range (2 ea) to slow it down for loader and forklift use.
M75 series is 1,2,3,4 and l,m,h,,think 85 is the same.
/ I bought the big one!! #26
That is 12x12. 12 forward and 12 reverse gears. I may be wrong, but I think the 105hp Mahindra is also 12x12. Mahindra really needs to think about a 16 gear tractor. While discing, my 6520 could use a few more in between gears.
hugs, Brandi
/ I bought the big one!! #27
Looks like they have 2 transmissions for the MForce 105. A 12x12 and a 24x28+8. The TYM T105 has a 32x32 not sure why Mahindra would use something else. IMG_1210.JPG
/ I bought the big one!! #28
Looks like they have 2 transmissions for the MForce 105. A 12x12 and a 24x28+8. The TYM T105 has a 32x32 not sure why Mahindra would use something else.View attachment 516828
Your right, but it's 24x24+8 Creeper Power Shuttle – Power Shift Transmission (105P)
I like power shuttle transmissions. Guess the +8 are creeper gears. Gotta go find one to play on.
hugs, Brandi
John Deere Metal Decorative Sign (A64557)
John Deere Metal...
1975 HOMEBUILT TR-AXLE LOWBOY TRAILER (A64278)
1975 HOMEBUILT...
2021 BOBCAT E50 EXCAVATOR (A63276)
2021 BOBCAT E50...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2175 (A65055)
2175 (A65055)
